Author Topic: A simple gas cap  (Read 4606 times)
A simple gas cap
« on: January 04, 2015, 08:58:43 PM »
When I first started to build i.c. engines, one of the issues that immediately came up was "What do I use for a gas tank, and how do I make a gas cap for the tank." I am not a fan of "pickle jars", as they break too easily, and there is always a great danger of a fire in the shop if this happens. I had a six foot length of brass thin-wall tubing from a recycled floor lamp, which seemed to be perfectly sized for a gas tank, and the beauty of it being brass was that I could solder to it. I tried a few different methods of machining a gas cap and filler neck, but since my largest tap was 3/8", it left me with a very small opening in the filler neck. The trouble with small filler neck openings is that you can never see how much fuel you are putting into the tank until the tank overflows, which again is a considerable fire hazard. Then one day, while browsing through pipe fittings at the local hardware store, I had a brain wave!!! If I used a standard threaded 1/2" pipe nipple, (which is 0.840" outside diameter x almost 5/8" i.d.) I could solder the nipple into the tank shell and use a purchased brass or bronze screw on cap with NPT threads. I found that the wall thickness on the short threaded pipe nipple has enough wall thickness to turn the threads off half of it to simplify soldering it into the tank shell. This picture shows one of these tanks with the pipe nipple soldered into it as a filler neck.
Re: A simple gas cap
« Reply #1 on: January 04, 2015, 09:00:10 PM »
This picture shows an "as purchased" bronze pipe cap, which costs about $5.40 at the hardware store. It is an ugly little cast beast, but it screws onto the pipe nipple perfectly with no fuss.
« Reply #2 on: January 04, 2015, 09:01:54 PM »
To turn a rather ugly little casting into a stylish gas cap, requires that you have a short (about 3") piece of 1/2" pipe with a thread on one end to set up in your lathe. Screw the cap tightly onto it, and turn the large o.d. down until you have machined away all of the cast surface of the large diameter (but no more).
« Reply #3 on: January 04, 2015, 09:02:24 PM »
Next, turn down the main body until you have machined away all of the cast surface, and face the end of the casting. There will still be a ring of cast surface visible because of the radius at the top of the cap, but don't worry about that for now.
« Reply #4 on: January 04, 2015, 09:03:11 PM »
Now we knurl the outside diameter. My scissor type knurlers won't let me knurl up tight to the large diameter, but that's okay, it lets me knurl enough. That knurl is very important, because the vibration of a running engine will tighten that cap into place so tight that you won't be able to unscrew it without that knurling to give you a good grip.
« Reply #5 on: January 04, 2015, 09:03:50 PM »
Once the knurling is completed, swing the top-slide around to 45 degrees and take a cut to get rid of the last remaining bit of cast surface.
« Reply #6 on: January 04, 2015, 09:04:32 PM »
Now remember--it is a rather nasty casting. The remaining face which is closet to the chuck jaws needs to have a clean up cut taken on it. For that, we use a cut off tool and do a plunge cut on the side closest to the chuck jaws, There is enough of a chamfer on the inside of the pipe cap that you won't have to run the cut off tool into the pipe itself.
« Reply #7 on: January 04, 2015, 09:05:11 PM »
Now there is one very important machining step left. Remember what I said about engine vibration tightening that cap up. Since it is an NPT thread, it will tighten itself to the point where your engine will quit, because it will be trying to suck fuel against vacuum created in the tank. I learned this after many head scratching sessions when running engines with the cap "unscrewed a bit" to prevent vacuum lock in the tank would quit for no apparent reason. I drill a 0.040" vent hole in the center of the cap. That is small enough that fuel won't slosh out under normal conditions, but the tank will always be vented to atmosphere no matter if the cap is screwed on tight or not.
« Reply #8 on: January 04, 2015, 09:06:14 PM »
And here we have it with the newly machined cap in place. We have turned a "sow's ear into a silk purse" with only an hours playing time in the shop.---And---We have a nice large filler neck so that we can actually monitor the amount of fuel we are putting into the tank.
Offline Alan Haisley
« Reply #9 on: January 05, 2015, 12:34:51 AM »
Very nice Brian.
Online Roger B
« Reply #10 on: January 07, 2015, 11:34:40 AM »
That's a nice looking tank  :praise2: I think I will build something similar to replace my plastic model car one.
Offline Stilldrillin
« Reply #11 on: January 15, 2015, 08:12:11 PM »
Just to show, I was paying attention.......
3/8 BSP fittings........
Finished assembly........
Thanks for the nudge, Brian!
David D
David.
« Reply #12 on: January 15, 2015, 09:09:47 PM »
Very nice. ----I built a new gas cap today--along with a new gas tank to go with it!! I had stolen the gas tank off my Webster about 4 engine builds ago, and never replaced it. i want to try out my modification to Chuck Fellows carburetor, and needed to build a tank to use the Webster engine. I never built a tank this shape before, but it is easier tha the style I have always built before.
« Reply #13 on: January 16, 2015, 12:58:49 AM »
Brian and David....those both look really nice and obviously can be used for both gasoline or an alcohol burner. Will be filing this one away for future reference. Thanks for sharing these.
