Author Topic: Mill Creep  (Read 12086 times)
Arbalest
Re: Mill Creep
« Reply #45 on: January 06, 2015, 07:52:47 PM »
I've got a small end mill with absolutely no teeth on the bottom at all, it's perfectly flat. Is this normal or has it missed a stage in production? It's brand new, never been used.
Might need a picture of that
Judging by the weight it's solid carbide, about 5mm.
Offline smfr
Re: Mill Creep
« Reply #46 on: January 06, 2015, 08:20:32 PM »
Looks to me like it's been ground down. Did you buy it new?
Simon
Offline Mosey
  • Rosemont, New Jersey, USA
Re: Mill Creep
« Reply #47 on: January 06, 2015, 08:21:24 PM »
Glad you reached a good solution  :ThumbsUp:  :ThumbsUp: Do you think that the old collet had worn to a taper?
So, you didn't buy the ultra precision collets,  you saving the money for "cutters :lolb: :lolb: :lolb: :mischief: :Jester:"
Cletus
Go to your room!
Offline Mosey
Re: Mill Creep
« Reply #48 on: January 06, 2015, 08:21:59 PM »
It would seem so!
Mosey
Arbalest
Re: Mill Creep
« Reply #49 on: January 06, 2015, 11:00:32 PM »
Simon
Yes. That's how it came, never been used.
Offline Allen Smithee
  • Mordor, Middle Earth
Re: Mill Creep
« Reply #50 on: January 06, 2015, 11:14:29 PM »
Is it just me, or does it look like the flutes spiral in the wrong direction as well?
AS
Online b.lindsey
Re: Mill Creep
« Reply #51 on: January 07, 2015, 12:03:45 AM »
I agree Allen...that's a strange one. I can only assume it was designed for a specific purpose though I have no idea what that is  :headscratch:
Offline GailinNM
  • Albuquerque, NM, USA
Re: Mill Creep
« Reply #52 on: January 07, 2015, 01:26:17 AM »
It's a Right Hand cut Left Hand spiral.  They are used extensively for profiling thin materials as they tend to force the work downward against a support so less clamping is required.  The profile is typically only a little oversize from the support.  They also have the advantage of the swarf is directed downwards where it can be collected easier. Since they are only used for profiling there is no need for cutting edges on the end.  I have used several of them.
Gail in NM
