Hi guys thought id let you know what a silly boy ive been! Trying to get my pup running but will only run for few seconds anyway this horrible noise started to come from the crank case !!!!!!!!! quite clearly some thing had gone amiss (I bet ive got your attention now) Well strip down (the engine not me) and I found the little end in the con rod well out of shape allowing the gudgen pin to rattle around !!!!!Then I rembered I made the con rods from HE30 ali not high strength stuff(technical term) and this had allowed a very high wear rate between the ali and phos bronze pin!!!.luck on my side, the con rods have quite a large head,so I drilled and reamed to take a phos bronze bush with new silver steel gudgen pins.Also drilled small hole in top of con rod to allow oil to enter.I loctited the pins in the pistons to ensure the only moving part would be silver steel against phos bronze.I caped the ends of the gudgen pins with ptfe pads (thats another story ) to ensure if they did move they would not score the ali cylinders.Back now to trying to get it to run properly...........That's what happens if you use the wrong materials !!!!!!!!!!!!!! regards mike.
