Author Topic: 1 eight scale 3HP buffalo marine twin  (Read 33358 times)
Re: 1 eight scale 3HP buffalo marine twin
« Reply #90 on: April 16, 2015, 07:36:56 AM »
Still following along and enjoying  :ThumbsUp:  :ThumbsUp: Splendid work  :praise2:  :praise2:
Offline mike mott
  • Alberta Canada
« Reply #91 on: April 17, 2015, 09:01:24 PM »
Dave Otto, Dave (steamer), Graham, Roger, thank you for you kind comments, it really means a lot coming from such accomplished builders.
the Carb needed to be rebuilt because I was not happy about a couple of things.
The adjusting screw was "knurled" by slipping the screw into a piece of 3/32 brass tube and lining up the edge of a file and rolling the file along the head pressing down to form the ridges.
A pencil to give it some scale.
I also added a proper flange to mount the carb to the manifold, it still needs a little shaping and the throttle lever added.
Offline 90LX_Notch
    • YouTube Channel
« Reply #92 on: April 18, 2015, 02:27:37 AM »
I knew it was small but the pencil really drives it home Mike.  Just awesome.  Very impressive build.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline mike mott
  • Alberta Canada
« Reply #93 on: July 11, 2019, 08:14:24 PM »
Just though I should let you all know that I am stalled on this model at the moment. I is close by and will resume at some point. currently I am working on a small steam loco, a 45mm gauge coal fired model of an 18 inch gauge Beyer peacock Shunting loco, but don't want it to look like a model loco with oversized fittings which is proving to be a challenge.
« Reply #94 on: July 11, 2019, 09:31:42 PM »
Did you "just find something more interesting"  ;) ...?...  in that case I'm sure many others here know the feeling  :-[
I probably shouldn't make anymore comments about this as a thought about glasshouses and stones comes into mind  :old:
The next question - are there any pictures of the new build ?
Best wishes
Offline mike mott
  • Alberta Canada
« Reply #95 on: July 11, 2019, 09:51:43 PM »
I still want to finish this engine but it is just on the back burner for now.
I started a thread in Vehicles.
