Author Topic: Another Hodgson Radial 9  (Read 44312 times)
Offline Camm-1
  • Sweden
Re: Another Hodgson Radial 9
« Reply #15 on: December 08, 2014, 05:28:00 AM »
Looks like your off to a good start. The heads are a machining marathon. I keep telling myself "You're not in any hurry, slow down and enjoy".
Hi ! Yes I realy enjoy it and I have slowed down to try being absolute sure how to do.
Have you start on the crancase? I start with the cylinders and went good untill I try finning one.
I couldnt get the tool to cut freely enogh so I m thinking of to reduce the finns some and make 1mm tool instead. :thinking:
Ove
Offline 1dbweldor
« Reply #16 on: December 09, 2014, 06:07:46 AM »
I ground my insert to .031 and .0015 relief on each side. I ran coolant on the parts and insert, turning 300 rpm with a slow hand feed. Also be sure to lock down the compound. This alone eliminates the chance of chatter and bit breakage.
 I've got some pictures on my camera to post in the next few days.
 Yes I've blanked in the cases and dressed them out to 2000 grit. In fact I started getting my mill cleaned up today to set my 4th up to start cutting chips on my cases.
Offline Camm-1
  • Sweden
« Reply #17 on: December 11, 2014, 07:44:22 PM »
Tonight I finished the lifterbushings and pressed them in with loctite 638.
Just 2 holes left to drill outside for the oilsuply before I can take it off.
I have to ream the bushings first to.
« Last Edit: December 11, 2014, 07:52:57 PM by Camm-1 »
Offline Camm-1
  • Sweden
« Reply #18 on: December 14, 2014, 07:53:45 PM »
All drilling finished only the oil holes from pump that must be done with the pump installed.
All tapping left..puhh.
Also started on the frontcover.
Offline Camm-1
  • Sweden
« Reply #19 on: December 15, 2014, 07:54:41 PM »
Continued the frontcover tonight and went for Terrys design on his 18 cyl on the other forum.
I like that look better, more beefy and counterbored screws.
I turned only by looking at it and change angle here and there on the topslide.
A little bit filing and wetsanding and a quick polish😊
« Reply #20 on: December 15, 2014, 08:22:32 PM »
Hi Ove, I am still there, very quite. Waiting for the  next steps.
Offline Camm-1
  • Sweden
« Reply #21 on: December 16, 2014, 05:23:38 AM »
Hi Achim!
Well I guess I will go on with the cylinders.
I have to get some bronse for the big bearings. And I know thw heads are not to play with.
The part that worries me most is the crankshaft.
Many fails doing the square hole conection thats in the plan.They dont get it in line and that stupid broach
is very expensive.
I think I will try Terrys way to turn it in one pice and cut it after that.
Ove
Offline mike mott
  • Alberta Canada
« Reply #22 on: December 16, 2014, 06:09:47 AM »
These radial engines are so complex , and it looks great so far.
mike
Offline Camm-1
  • Sweden
« Reply #23 on: December 26, 2014, 05:17:43 PM »
Some more progress on the cylinders.
Got my tool to cut well but grind it a bit to small so it been 15 grooves instead of 14 :)
Have still six more to turn in the down end and then the threading that will be 1mm pitch.
« Last Edit: December 26, 2014, 05:21:18 PM by Camm-1 »
Offline metalmad
« Reply #24 on: December 26, 2014, 11:10:20 PM »
Hi Ove
That Crankcase is looking really lovely  :praise2: :praise2:
Offline Camm-1
  • Sweden
« Reply #25 on: December 27, 2014, 08:05:26 AM »
Thanks Pete!
I realy want to recomend to build this engine to they who hesitate.
I enjoy it so far.
I like the words" Thats what is impossible just take a bit more time"
Offline Camm-1
  • Sweden
« Reply #26 on: December 27, 2014, 01:40:52 PM »
Today I turned the last cylinder now its time for threading.
I still have all 11 except for the first thar have ugly finns. Should have tryed it out better first on some scrap.
Offline crankshafter
  • Molde, Norway
« Reply #27 on: December 27, 2014, 03:17:00 PM »
Hi Ove.
exelent work Ove.
Tempting tempti temp te..... Oh well I will go and have my pills. Or better a Aquavit or three :lolb: :lolb:
CS
"I cut it twice, and it's still to short"!!??">#%
Offline Camm-1
  • Sweden
« Reply #28 on: December 27, 2014, 03:48:54 PM »
Hi CS
Do that. I am just sitting taking a good whiskey with friends that came up for newyear.
A happy new year to you up there in Norway.
« Reply #29 on: December 27, 2014, 04:45:45 PM »
These radials are quite a project and your progress is amazing Ove. Very nice work!!
Database Error
Back
