Author Topic: Mills Brothers 1.3 Diesel  (Read 11392 times)
Offline Graham Meek
« on: November 12, 2014, 05:43:20 PM »
Can anyone who has built the above engine from the Motor Boys drawing help me out.
I have a retired Anaesthetist  friend who is trying to build this engine and he has asked me to look through the drawings.
I have been looking at the Venturi detail, it says to drill through #32 (0.116") drill and flare out each end at 8 degrees inclusive. The Venturi is tapped 1/8 Whitworth to take the spray bar which means there is no venturi. Is the #32 a typo error, or is the spray bar wrong?
There is also no sizes given as regards the fuel outlet hole size on the venturi centre-line. Should this hole be just on the engine side or all the way through?
My best regards
Gray,
Re: Mills Brothers 1.3 Diesel
« Reply #1 on: November 12, 2014, 06:36:38 PM »
Gray, I think the idea is to screw the spray bar into the venturi before it is drilled, solder and then drill the venturi #32 which will also drill through the spray bar. This is for the Built up carb not the cast one.
Do you have access to teh build that was published in MEB?
Offline Graham Meek
« Reply #2 on: November 12, 2014, 07:24:44 PM »
Hi Jason,
Thanks, that would make sense, only having A4 copies of parts of the original drawing I am probably missing some vital information contained in some notation not shown on the A4 copies.
I did not know this engine had been published on MEB, I have not considered joining this site as generally I am not into building published designs.
My best regards
Gray,
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #3 on: November 12, 2014, 07:50:17 PM »
Hi Gray - how are you?
I can't find any ref to this engine either in the Motor Boys book or on the MEM site. Doesn't figure under 'Plans' nor 'Projects' on there and it's not in the members area either.
Have I missed something somewhere  ::)
Can you point me in the right direction or post the drawing up.
Regards - Ramon
« Reply #4 on: November 12, 2014, 08:55:44 PM »
Check your e-mail Ramon for relevant drawing
Offline Graham Meek
« Reply #5 on: November 12, 2014, 09:09:20 PM »
Hi Ramon,
I hope you and Sue are OK?
It is that time of the year when my health usually takes a nose dive, just after the Flu jab, but touch wood, this year has not been as bad as previous years. Each day I am seeing a steady improvement so I am not grumbling.
I have been enjoying your recent post, and learning a few tips along the way. I am convinced my friend has sent these drawing as a ruse to get me to make a Mill's, he has been on about this engine for years. Unfortunately with the work on my Fiat tractor and my own 4 stroke diesel I already have too many things going on.
Take care,
Gray,
Offline SandCam
  • West Coast of Scotland UK
« Reply #6 on: November 12, 2014, 09:33:30 PM »
Hi Guy's,
I believe the drawings and build article for the Mills 1.3 were published in 'Model engine Builder' magazine... issue 1.
I don't subscribe to this at the moment but I believe Ramon does/did.
Perhaps he has a copy of that issue.
Hope this helps track down things.
best regards and good luck.
Sandy. :cheers:
« Last Edit: November 12, 2014, 09:37:07 PM by SandCam »
« Reply #7 on: November 12, 2014, 09:40:52 PM »
Yes drawings and a long build article were in the first issue of MEB.
Offline GailinNM
  • Albuquerque, NM, USA
« Reply #8 on: November 12, 2014, 10:01:24 PM »
Here is a link to the general arrangement drawing on Model Engine News website showing the needle valve arrangement.
Gail in NM
  • Suffolk in the UK
« Reply #9 on: November 12, 2014, 11:02:33 PM »
Hi Gray - yes we are both fine. I've yet to experience the pleasures of a flu jab - hope that recovery improves dramatically.
Thanks for the drawings and text Jason. Strange it's a Motor Boys drawing but not apparently on MEN.
It would 'appear' you are correct in that the spray bar is soldered into the venturi then the venturi is through drilled. I say 'appear' as though it does draw attention to the fact "Note we have not drilled the #32 hole right through yet" it goes on to explain the soldering then setting the needle in it's holder omitting, as far as I can find, any reference to further drilling the venturi through.
I recall repairing a Mills .75 (replica) about a year ago. The venturi had an enlarged section where the spray bar was located. The (ali) spray bar was removable in one piece and had a nut on the top side to keep it captive. Larger in diameter than the venturi bore it had been drilled through in situ to leave very thin (and weak) walls. Another option Gray?
Regards - Ramon
Offline Maryak
« Reply #10 on: November 13, 2014, 12:06:31 AM »
Hi Guys,
The 3cc OB Bolton diesel has a similar arrangement below is a detailed drawing of the fuel system.
Hope this helps
Best Regards
Offline rklopp
« Reply #11 on: November 13, 2014, 05:12:11 AM »
I can confirm that the Mills 1.3 venturi per MEB/Ron Chernich plans is built by screwing in the spray bar, soldering it top and bottom, and then drilling through the venturi throat.
I built two, and they are about my favorite engines. They are super easy to start, and not terribly loud.
« Reply #12 on: November 13, 2014, 07:35:08 AM »
Gail's drawing is for the version with the cast venturi, Gray is talking about the built up one. The idea is to make the spray bar as one so that the needle will be in line with the seating rather than two pieces top & bottom of teh venturi which will be very hard to get to line up
I think Ron did the drawings and 18 page build article as a special for the first edition of MEB mag. Engine is said to be based on the Mills Brothers ( Model Engineers) "Mills1.3" which is based on teh French Allouchery 1.25cc
Offline Graham Meek
« Reply #13 on: November 13, 2014, 09:52:54 AM »
Hi Jason,
A picture paints a thousand words as they say, all has now become clear.
I did wonder if anyone has seen the "Throttled" version? Some photographs and drawings of this would be handy for use on other Diesel engines.
My best regards
Gray,
Offline tedsmith
  • Jr. member
« Reply #14 on: April 14, 2015, 02:24:40 PM »
hi can any one help me with a full set of drawing for ron chernich mills 1.3 Diesel engine, which I wish to to fit into my
DH9A plane hope to hear for some body soon regards ted smith .
