With only a little more trouble it could be generalized to most any size of wire and pitch and diameter. Marv has a program, I think based on Kozo's equations, called Mandrel that determines the mandrel size needed based on wire size and final ID needed. Combining that for the diameter and threading a piece of steel to the approximate TPI to give the spring turns per inch needed should work for a wide variety of diameters and wire sizes and spring ID's.
So, thank you Marv for the library of programs.
