Author Topic: PEEK as a bearing in flame eater/stirling engine?  (Read 7413 times)
Offline machineshed
« on: November 01, 2014, 06:30:01 PM »
I'm making a couple of engines and can't fine enough ball bearings, But i have got a load of peek!
Has anyone tried PEEK as bearing on a striling engine or a poppin???
Thanks Jim
Re: PEEK as a bearing in flame eater/stirling engine?
« Reply #1 on: November 01, 2014, 08:03:48 PM »
Jim, I have never tried it but most stirlings and flame eaters require ball bearings or else the friction becomes too much for the power of the engine to overcome.
Offline Stuart
  • Tilchestune UK
« Reply #2 on: November 01, 2014, 08:52:58 PM »
Not used it as a bearing but I have made piston valves from it for live steam locomotive , only the valve bit like a polo mint on each end
But it's very expensive about £60 for 25mm dia by 300 mm
So I envy a sock of lots
Sorry Stan I meant stock , dyslexia problems
« Last Edit: November 02, 2014, 01:05:10 PM by Stuart »
Offline gldavison
  • Tarkio, Mo.
« Reply #3 on: November 01, 2014, 09:57:52 PM »
What is PEEK?
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
« Reply #4 on: November 01, 2014, 09:59:53 PM »
Maybe this will help.
http://en.wikipedia.org/wiki/PEEK
« Reply #5 on: November 02, 2014, 04:28:36 AM »
May by some additional information are shown here.
http://www.ensinger-inc.com/products.cfm?page=product&product=tecapeek
Offline sshire
    • LS Editions
« Reply #6 on: November 02, 2014, 11:26:46 AM »
What is a ""sock of lots?" I was sure that the time spent on this forum, along with my "English to English Translation Dictionary" had gotten me to the point where I knew what was being said. I'm still shaky on the "Oz to English" however but that's another story.
Best,
Stan
Arbalest
« Reply #7 on: November 02, 2014, 11:37:29 AM »
Peek wouldn't be my first choice for bearings. Not cheap but I bought some Ertalyte TX rod to make the track and bolt retainer inserts on my target crossbow. Excellent stuff, machines like Acetal but very slippy!
http://www.quadrantplastics.com/fileadmin/quadrant/documents/QEPP/EU/Product_Data_Sheets_PDF/GEP/Ertalyte_TX_PDS_E_25012011.pdf
Offline machineshed
« Reply #8 on: November 03, 2014, 06:37:07 PM »
Thank you for the replies.
I'm going to go ahead and try the PEEK, if it doesn't work, I'll have to get some bearings!
Cheers Jim
« Reply #9 on: November 03, 2014, 09:01:07 PM »
Jim, if it works then we will all have learned something. Please keep us posted on if and how it works. As the saying goes..."nothing ventured, nothing gained."
Arbalest
« Reply #10 on: November 03, 2014, 10:22:00 PM »
For what it's worth I even washed out the oil on the bearings for my flame eater to reduce friction to a minimum. The addition of some graphite powder may help if you're going to go solid with some Peek.
Offline kellswaterri
« Reply #11 on: November 22, 2014, 11:42:51 AM »
Hi folks,....re.   Peek.  I sent just on Thursday last,for some info, on Peek rod  to make some bearings, hopefully I might be able to obtain a small sample  Gratis.
« Reply #12 on: November 29, 2014, 10:09:41 AM »
Hi folks...those Very Nice people at  V......  must not have wanted me to have a Peek at their PEEK...as there was no reply to my email
for information + a sixty metre sample   Sorry ,finger slipped... 6 MM  ...I hope to hear from then ...soon.
Offline Ian S C
« Reply #13 on: November 29, 2014, 10:29:24 AM »
I use carbon impregnated Teflon for the gland bush of the displacer on some of my Stirling Engines,  It's good, but try not too get oil on it.  You could make some cast iron bushes, with a polished shaft the friction is not too much greater than ball bearings.
                                                Ian S C
Offline Stuart
  • Tilchestune UK
« Reply #14 on: November 29, 2014, 11:35:21 AM »
its not worth trying to scrouge a bit of peek although I do not think its the best stuf for your job
http://www.directplasticsonline.co.uk/PeekRod/6mm/
just over £3
