Author Topic: Scott Vacuum Engine......  (Read 62172 times)
Offline PJW
Re: Scott Vacuum Engine......
« Reply #15 on: November 08, 2014, 09:19:36 AM »
Hi I have been following the log & I need a coil spring for my little Kickstart, steel tape, thanks :cartwheel:
Old Guys Rule the Dark Side of the Shed!
Offline AussieJimG
  • Bywong, NSW, Australia
« Reply #16 on: November 08, 2014, 09:43:26 AM »
Your projects are always interesting David, and this one is no exception.
fcheslop
« Reply #17 on: November 08, 2014, 11:57:03 AM »
Hi David, nice going :ThumbsUp:
For the valve I normally just use feeler gauge as in the ones we used to set points with or the tappets .
May not be large enough for youre engine. Just make a little punch and block to make the hole a bit like the toolmakers shim punch blocks or trap it between two bits of scrap to drill the hole.Telling me granny how to suck eggs :Lol:
It maybe beneficial to knife edge the back of the flame hole as per poppin it does seem to help.
Oh well back to my conundrum Iv dug a hole :censored: :hammerbash:
cheers
Offline Steamer5
  • The "Naki" New Zealand
« Reply #18 on: November 08, 2014, 07:55:30 PM »
Hi David,
 Another rescue operation, well done! And another interesting "how to fix it".
Had a friend who was into clock making who was also in need of a spring like you are hunting for used a feeler gauge, he hunted for a while & found a set that would of been 100 plus mm long....its been some years & hes no longer around. Maybe be worth a look
Cheers Kerrin
Offline Stilldrillin
« Reply #19 on: November 08, 2014, 08:54:06 PM »
Thank you, Jim!  :ThumbsUp:
It's nice to know you're out there again. Supporting, as usual......  ;)
David D
David.
« Reply #20 on: November 08, 2014, 09:03:06 PM »
cheers
Hi Frazer.
The slot is 22mm wide. But, I've got plenty of shim, to practice with......  ;)
Just keep on telling (reminding), granny. This old un, needs a nudge, now and again.  ::)
I am planning to chamfer the slot. Should be "fun", with a ball end cutter.
Good luck, with your conundrum. I'll stick with this one, for now. :ThumbsUp:
David.
David.
« Reply #21 on: November 08, 2014, 09:10:06 PM »
Hi David,
Cheers Kerrin
Hi Kerrin.
Thanks for your kind comment. Also, for the feeler gauge tip.  :ThumbsUp:
I've had a veritable chorus of members, from two forums. All with the same idea.
Why didn't it occur to me?  :embarassed:
David D
David.
« Reply #22 on: November 09, 2014, 09:19:14 AM »
Jon.
The available tape return springs, measure up at only 2 thou thick. Handy to remember, though. Thanks for the tip!  :ThumbsUp:
Feeler gauges....... Hmmm.....  :thinking:
Not given them a thought, for the past 20 years, or so. No need, for modern vehicles.  :shrug:
Just been rummaging, in my old toolboxes........
What a trip, down memory lane!  ^-^
The central one. For my first motorbike. Came from the Brighouse branch of Woolworths, 1960. Cost 1s 3d.
The lower one was bought for my brand new, 1965 BSA Lightning.
The top one, when I went metric. Around 1980.
I've got all the spring steel I need...... Thanks for the posts, and pm's Fellas! Much appreciated.  :cheers:
David D
David.
« Reply #23 on: November 09, 2014, 09:51:44 AM »
The lower one was bought for my brand new, 1965 BSA Lightning  :Love:  :Love:
Mine wasn't new when I had it, as you may have guessed you brought yours before I was born  ;)
fcheslop
« Reply #24 on: November 09, 2014, 03:57:45 PM »
Oh David, my sympathies thats on big confession an A65 :embarassed: :facepalm2: at least it wasnt the Barracuda or Spitty.
My last new brit was a T140v 1977 what a bit of junk :facepalm: blew up 10 miles from the dealers.
Small wonder youre good at fixing the orphans :Jester:
« Reply #25 on: November 10, 2014, 09:04:37 AM »
Frazer.
Many a true word........  ::)
Bought, when Jo was merely a twinkle. I've never since, owned a worse collection, of of poorly designed/ mis matched/ badly assembled parts.
I still have the l/h piston, with it's detached crown. Very memorable ride home from the Yorkshire Dales on one cylinder, and a close ratio gearbox.........  :ShakeHead:
Whoever got it, after my 2 years ownership, got a good un.
To me, it was a waste of a hard earned £341 12s 3d. I never bought another new vehicle, until last year.......  ;)
David D
David.
fcheslop
« Reply #26 on: November 10, 2014, 03:38:47 PM »
Ah hindsight is a great thing.I had two A50s and always wished Id kept my A7s.
Although Im still not cured as there's still a couple languishing in the garage :lolb: ones even a BSA although Im getting to old and fat for the drops maybe time to put it into touring trim and buy one of those leccy start kits :naughty:
Now Jo as a twinkle I can handle. Its the Tu Tu guys that worry me :mischief:
cheers
« Reply #27 on: November 10, 2014, 05:11:50 PM »
Now Jo as a twinkle I can handle.  :o
Are you sure  :LittleDevil:
« Reply #28 on: November 10, 2014, 06:02:41 PM »
Managed a few workshop minutes, this afternoon.  :)
Assembled. Then realised, I'd forgotten the leaf spring!  :facepalm:
The little coil spring, saved the day.......
Gave it a flick....... And it stuttered into life!!.......
You know that supreme moment.  :whoohoo:
When the blood pressure goes sky high. And, all you want to do, is dance about, for joy.  :pinkelephant: :pinkelephant:
It's A RUNNER!!!!   :cartwheel: :cartwheel: :cartwheel:
Well...... SOMEONE, was knocking on the door........ "Grandad"....... I nearly burstO:-)
I had a Little Helper, for the rest of the afternoon.......
<a href="https://www.youtube.com/watch?v=ahN_-4pIVDc" target="_blank">http://www.youtube.com/watch?v=ahN_-4pIVDc</a>
I bet Steven Spielberg, never had such a helper.......
<a href="https://www.youtube.com/watch?v=CML7EN2XX1c" target="_blank">http://www.youtube.com/watch?v=CML7EN2XX1c</a>
Love it!
David D
David.
« Reply #29 on: November 10, 2014, 06:55:36 PM »
 :ThumbsUp:  :ThumbsUp:  :ThumbsUp: What more can I say  :)
