Author Topic: Scott Vacuum Engine......  (Read 61828 times)
Offline Stuart
  • Tilchestune UK
Re: Scott Vacuum Engine......
« Reply #135 on: April 22, 2015, 02:25:44 PM »
David
 It's a quacker of a engine  :Jester:
Sorry could not resist a pun
« Reply #136 on: April 22, 2015, 02:44:44 PM »
Yep, it a quacker alright, but it sure runs nice and looks great David!!
Offline sbwhart
  • Live Long and Prosper
« Reply #137 on: April 22, 2015, 05:57:08 PM »
Bloody hell Dave you've built a Chesterfield Duck  :Jester: :lolb: :lolb:
The video drove me Quakers
Looking good but sounding:----------------- ducky
Stew
Offline ths
« Reply #138 on: April 22, 2015, 10:23:43 PM »
Would oil help? Anyone would smile at that. Hugh.
Offline NickG
« Reply #139 on: April 25, 2015, 07:24:30 AM »
Haha classic video Dave!
I think it could be the reed type valve being blown off its seat then vibrating in its guide? Might help setting the timing to open a bit earlier although the good thing about these is, you don't need to worry about the valve open timing too much as it is light enough to be blown off its seat when the engine is good and ready. That, I guess could depend on many factors such as cylinder temp. How much and how hot the air its drawn in is etc. Could your guide be restricting this happening and slowing the engine down?
Offline Stilldrillin
« Reply #140 on: April 25, 2015, 10:46:07 PM »
Thank you for all your comments Chaps!  :cheers:
I dunno where the duck came from, or why! I hadn't made any drastic changes...... :headscratch:
Not too much to show, for this week. But....... I've almost finished the final build!
I'm making several mods, and upgrades as I go along.
Before finally sealing the cylinder into the hopper, the bore caught my eye. All that time spent honing, was worth it........
Seven ball races, in the crank assembly. The fixed crankpin, links the two halves together.........
Then, the whole assembly is held by two countersunk M6 screws......
Building a bit. Test running a bit........ I'm pleased to report, the duck has flown! Normal popping has returned........   :whoohoo:
Thanks for looking in!
David D
David.
« Reply #141 on: April 27, 2015, 10:36:55 PM »
I'm doing the fiddly, finishing, faffing about, at the moment.  :(
Rolled up a pair of stainless mesh, wicks. Action photo........
The finishing line is in sight!
Thanks for looking in.
David D
David.
« Reply #142 on: April 27, 2015, 10:54:34 PM »
Dave beautiful work and I have to ask. How do you get such a blue flame from the meth?
« Reply #143 on: April 27, 2015, 11:05:47 PM »
Hi Don. Thank you!  :cheers:
I have started making my wicks from stainless steel, 100 mesh. As they do not burn down, nor rust.
They always give a mostly blue flame, compared to the stove rope, I have previously used.
Note, on this earlier video. The l/h burner is stove rope, r/h burner is 100 mesh........
<a href="https://www.youtube.com/watch?v=2KALEUREuEs" target="_blank">http://www.youtube.com/watch?v=2KALEUREuEs</a>
David D
David.
« Reply #144 on: April 27, 2015, 11:49:29 PM »
Interesting result on the wick comparison David. Maybe the mesh allows more air to mix with the meths giving cleaner combustion. Just a thought but the difference is obvious.
Offline Graham G
  • NZ
« Reply #145 on: April 28, 2015, 07:46:36 AM »
hi there David D,  I do like your blue flame and I have to wonder if a copper wick would give you a green flame, also I am very impressed with your camera talents.
Graham
« Reply #146 on: April 28, 2015, 11:21:42 AM »
Hi Bill.
I really, don't know the reason.
This wick is not quite as efficient as the fibreglass stove rope. Though I prefer it, for it's durability.
I tried all the different wire permutations, during my Bengs, Nick, build saga. They rusted, once the galvanise had burned away.  :(
Hi Graham.
Copper wick? No!
I think the copper, conducts too much heat out of the flame.  :ShakeHead:
Thanks for the camera comment!  :cheers:
Both still, and video's, are taken on my Motorola phone's camera. I don't use my Panasonic, any more.  :shrug:
David D
David.
« Reply #147 on: April 28, 2015, 12:05:26 PM »
You had me worried there David I thought you had killed the quack   :LittleDevil:
« Reply #148 on: April 28, 2015, 08:22:07 PM »
Jo.
Not killed. Controlled.......
Today, I made a shutter template/ drill jig. (R/h end).........
Testing several different blades, I found some of them quacked.  >:(
Until, I turned them around.
Must be the varying resistance, to bending away from the port.  :thinking:
David D
David.
« Reply #149 on: April 28, 2015, 08:26:27 PM »
I'm late in saying this is a very nice engine. Thanks for the stainless steel wick hint!
