Still following along It's always good when someone tries to investigate the fundamentals rather than just accepting what has gone before
One problem remains. At high pressure, the end of the valve body is forced against the end cap and the resulting friction makes it difficult to close the valve for early cutoff. The valve is opened by the linkage through the wrist plate to the eccentric, but when the Reynolds release trips, the only force available to close the valve is the weight of the dashpot. It takes a weight of more than 2 ounces or about 60 grams to close the valve sharply at 45PSI operating pressure. I have to work on that. since the details of the valve are hidden, I will post a 3D view of the design shortly.Jerry
