Author Topic: 1/4 scale traction engine governor gear repair  (Read 2219 times)
Offline Bobsmodels
« on: October 01, 2014, 11:28:59 PM »
See two posts down for entire original post on another site.
Hi
Just thought I would post a note here. I have a 1/4 scale 24hp Minneapolis traction engine that needed the gears on the governor repaired. I was getting assistance on the SmokStak traction engine site and if you want to see my solution go to this thread. There is a youtube link and two PDF files detailing the gear layout using Law's book. It also details the approach I finally took (using miter gears).
 Again just an FYI for those who have one of these engines.
http://www.smokstak.com/forum/showthread.php?p=1089932#post1089932
« Last Edit: October 03, 2014, 01:30:57 PM by Bobsmodels »
Offline Stuart
  • Tilchestune UK
Re: 1/4 scale traction engine governor repair
« Reply #1 on: October 02, 2014, 08:48:48 AM »
The PDFs are not available unless you register
Could you not link them here
Offline Bobsmodels
« Reply #2 on: October 03, 2014, 01:32:06 AM »
I was not aware of that, here is the entire post.
Hi all:
 First, I want to thank all who helped out with ideas and information on this project.
 To make a long story short I went from laying out and designing the gear using Law’s book on gear design to a final answer that used readily available miter gears. I opted for miter gears rather than bevel gears for a number of reasons. Primarily they required the least amount of effort to implement. The idea for miter gears came from a fellow modeler who pointed out some other approaches to gears.
 The project is done and the governor works just fine as you can see in the video link.
 I have attached two PDF files due to site size restrictions with all the information I gathered.
 The first PDF file starts with a discussion of choices. There is a complete layout for the 22 and 33 teeth gears for those who might want to try that approach. Then there are pictures of the ¼ Scale Minneapolis setup at the Rock River Thresheree.
 The second PDF file contains a detailed discussion of the miter gear choice and of how I made the changes and the specific gears I used (lots of pictures). The total time from when the gears arrived to running on the engine was two days, not all of which was in the shop. I think I spent about 12 hours on the project once the approach was chosen.
 Thanks again
« Last Edit: October 03, 2014, 01:35:27 AM by Bobsmodels »
Offline Stuart
  • Tilchestune UK
« Reply #3 on: October 03, 2014, 07:49:29 AM »
Thanks Bob
