Author Topic: Scaling port dimensions  (Read 2395 times)
Offline kev
  • Portsmouth UK
« on: September 24, 2014, 01:45:57 PM »
Im making a 2x scale elmers #24 beam and an thinking of drilling the cylinder soon.
General question concerning port sizes, should I just double the linear dimension ie diameter or double the port area?
For this piston type valve im thinking double the diameter will keep the timing right but other engines maybe its the area.
Im sure for a toy it does not matter a jot but im generally interested
Offline Maryak
Re: Scaling port dimensions
« Reply #1 on: September 24, 2014, 10:22:37 PM »
Attached is a spreadsheet for steam port area.
The original info courtesy of Sandy Campbell.
Best Regards
Offline Alan Haisley
  • Near Clayton, North Carolina, USA
« Reply #2 on: September 30, 2014, 08:37:46 PM »
Best Regards
Bob/Sandy,
This spreadsheet has an error. Please examine the formula in cell B9. This reads as =B13/12*2*B15. The B13 term should be B14. i.e., it needs to be the stroke rather than the bore.
In the example given the result is OK because the bore and stroke are the same.
Alan
Near Raleigh, NC, USA
Offline Maryak
« Reply #3 on: September 30, 2014, 11:08:10 PM »
Alan,
Don't blame Sandy, blame me, it's my spreadsheet and you are quite correct.
So...........thank you for finding and fixing the error.  :NotWorthy:
Best Regards
Offline SandCam
  • West Coast of Scotland UK
« Reply #4 on: October 01, 2014, 01:49:54 PM »
Hi Guy's,
Thanks for correcting that error Alan.
Bob,
I have taken the opportunity to add some other alterations to the spread sheet, specifically for the port dimension calculations based on standard slide valve design practice.
It will now calculate port length and width automatically for changes to BORE, STROKE and RPM.
Your fixed 0.094" width gave some great fun answers if you increased the stroke too much... try 27" with your original and you will see what I mean.
I have also added/expanded some of the notes.
Hope you approve.
Best regards.
Sandy. :old: :cheers:
Offline SandCam
« Reply #5 on: October 01, 2014, 01:56:37 PM »
Hi Kevin,
Yes, just double the port dimensions otherwise you will need to alter the piston valve dimensions and possibly the eccentric throw... so keep it simple.
If you were starting from scratch then you could design it in accordance with the general design rules as given in Bob's spreadsheet (now Modified).
Hope this helps.
Best regards.
Sandy :cheers:
Offline Maryak
« Reply #6 on: October 01, 2014, 11:40:42 PM »
Hi Guy's,
Hope you approve.
Best regards.
Hi Sandy,
Thanks for your amendments much appreciated. (Downloaded and saved). The 0.094" was not "fixed" but could be changed at will to alter the other one to give good sized ports. It probably would have helped a lot if I had been smart enough to annotate that!
Best Regards
« Last Edit: October 01, 2014, 11:43:53 PM by Maryak »
Offline kev
  • Portsmouth UK
« Reply #7 on: October 22, 2014, 10:27:44 PM »
Thanks guys, thanks Sandy, I have just gone ahead and doubled the diameters, should be fine but still a couple of weekends off trying to run it, here is the current status:
the engine block seen here is just being worked on now
