Author Topic: My workshop  (Read 10201 times)
Offline pgp001
  • West Yorkshire - UK
Re: My workshop
« Reply #15 on: March 25, 2015, 12:59:35 PM »
I agree
As long as the bed has no twist or misalignment then all is well.
I have my lathes set so that the coolant drains to one end effectively.
Phil
Re: My workshop
« Reply #16 on: March 26, 2015, 01:31:32 AM »
It may not be absolutely necessary, but a lathe can seem straight but be twisted and I think I've used some of those ones. Runs a taper when there was no reason for it and I was always polishing it out. I think it helps overall accuracy, and eliminates a potential problem. And my friend has a machine level and all it cost me was a beer :DrinkPint:
Offline Stuart
  • Tilchestune UK
Re: My workshop
« Reply #17 on: March 26, 2015, 08:04:19 AM »
I will pose a question re machine levelling
On a long machine and the ones that do not have a bed persay only a pad to set up the carage and tail stock ,levelling is not possible in the normal way , because the said machine including steam turbines for power generation sit on a big ball , so if the ends are level then the middle Is high?
So we're is the level here .
The old way before lasers was to use a wire but this still left the middle high ?
Just a bit of thinking out loud so to speak
Offline Mark
  • NW UK Just getting started with Model Engineering
    • My weather station wensite
Re: My workshop
« Reply #18 on: May 28, 2015, 02:13:32 PM »
Hi Art
Workshop is looking good have to say though I have Mill envy  :)  have watched a lot online about those Tormach CNC mills they look great John over at NYCCNC https://www.youtube.com/user/saunixcomp on YouTube has some great videos about setting up and using might be of use to you.
Hope all progresses well.
Regards
Mark
