Author Topic: Adding a DRO to my mill  (Read 7896 times)
Online sco
Re: Adding a DRO to my mill
« Reply #15 on: September 14, 2014, 09:11:01 PM »
Hi Jim,
I think I use my mill the opposite to you - so on mine the quill feed just has some crude 1mm divisions so I use the head fine feed which has 0.05mm divisions for precision work.  So I have the dro for the position of the head and will continue to use the quill for drilling when I'm not fussy on depth.
With them being magnetic do you have to take care with mag bases?
Simon.
Ars longa, vita brevis.
Online sco
« Reply #16 on: September 15, 2014, 09:29:49 PM »
Only had half an hour of play time in the workshop tonight but can already see the benefit of the graphical display - picture below shows using the PCD function - you can set the start and end angle and it updates the picture to show your entered parameters.  So I entered a start angle of 25 degrees and end angle of 360 degrees with 8 holes - as you work through the holes it updates the display so you can see where you are - surely much less chance of lulus!
Simon.
Offline Jim Nic
  • Buckingham, UK
« Reply #17 on: September 15, 2014, 11:28:58 PM »
Hi Simon
On the very rare occasions that I have used magnetic bases I can't say I noticed any interference with the mag tracks on my DRO. I would be surprised if such a thing did occur given the close proximity that the read head has to be to the track in use.
Nice display, wish I had one of those.  You will, I am sure, have realised that in your run through of the PCD function you have ended up with unevenly spaced holes because you omitted to add your offset starting angle to the final position. (or is it subtract - no matter, your lovely display will show you when you have it right  ;) ).
« Reply #18 on: September 19, 2014, 07:30:22 AM »
I do like that ability of the graphical displays but sadly it looks like my next mill won't be getting one as the machine I am looking at already has a Topaz display with Spherosyn linear encoders  :whoohoo:
All I need is to find the space for it  :slap:
« Reply #19 on: September 19, 2014, 07:50:00 AM »
You could always buy a better display than the Topaz which would take the scales ;)
Got your heart set on that one then :cartwheel:
PS Do you think I will get a finders fee
« Reply #20 on: September 19, 2014, 07:52:01 AM »
If you are quick you might get one of my muffins  ;)
Online sco
« Reply #21 on: September 19, 2014, 08:24:57 AM »
Quick at what?
And what's this about a new mill - Sexy is barely bedded in surely?
Simon.
« Reply #22 on: September 19, 2014, 08:42:07 AM »
 :embarassed: I have only arranged to go and have a little look.
I might just take my cheque book :mischief:
« Reply #23 on: September 19, 2014, 08:43:35 AM »
Simon, I think jo feels the need for something larger!
Jo Keep your muffins hot, I won't be long and I come bearing gifts.
Online sco
« Reply #24 on: September 19, 2014, 08:53:53 AM »
I've been hankering after something smaller;
http://www.lathes.co.uk/advertphoto/140916boleydrill/
« Reply #25 on: September 19, 2014, 08:59:30 AM »
You don't want one of those, no use for through holes as there is no clearance hole in the table :LittleDevil:
Online sco
« Reply #26 on: September 19, 2014, 10:09:46 AM »
Just needs some lateral thinking....
Enjoy Jo's muffins.
« Reply #27 on: September 19, 2014, 02:13:43 PM »
They didn't last long  ;)
Online sco
« Reply #28 on: September 19, 2014, 02:31:17 PM »
Never mind the muffins what about the mill?
Offline ths
« Reply #29 on: September 19, 2014, 03:12:02 PM »
What are those interesting looking wooden items? Hugh.
