Author Topic: Lathe/Mill upgrade ???  (Read 2973 times)
Offline 1hand
  • Wisconsin, USA
« on: August 01, 2012, 01:26:07 AM »
Hi,
I'm starting to look around at adding a bigger mill and lathe to my arsenal. I currently have an 9x19 lathe and a SX3 mill, both I have converted to CNC. Looking for something more rigid and bigger. Probably a 12x36 or so lathe, and maybe a knee mill. I might CNC the new mill later on, so that would be something to keep in mind. Like to stay with the R8, due to a ton of tooling I already have for that. Single PH 220 would be the biggest voltage I can go. Will be going in the garage shop so size isn't a problem, as it would be in the basement shop.
Looking to see what you guys got in these sized machines, and your pro's and con's on the different ones. :thinking:
Matt
Offline 1hand
  • Wisconsin, USA
Re: Lathe/Mill upgrade ???
« Reply #1 on: August 04, 2012, 08:16:34 PM »
Think I've found the replacements! :bandrock:
Quite a bit more than I first was figuring, but in the long run, I think I will be ahead by going with these. :slap:
It will just take a longer time before I can swing the price tags. Hoping maybe in the next 12 to 18 months if all goes right. :LittleAngel:
Matt
« Reply #2 on: August 16, 2012, 01:46:34 AM »
It doesn't look bad Matt.....who's the distributor....and the maker?
