Author Topic: another Snow engine  (Read 158885 times)
Re: another Snow engine
« Reply #555 on: December 20, 2016, 02:47:08 AM »
Very nice Achim!
I hate seeing it coming to an end; but I'm sure you have another project waiting.
Daev
« Reply #556 on: May 07, 2017, 02:37:04 PM »
Hi Dave,
due to some special circumstances, I had to make a brake with the Snow engine, so we will have some more time to an end.
As mentioned in the Hoglet post already, I try to improve the clamping of the taper in the flywheel.
The machined taper in the cast iron flywheel has not the best surface quality, I have to speak with the guy who has made it.
So after disassembling the flywheel my idea was a kind of grinding or better lapping action to get rid of some friction between taper and flywheel.
The taper and a piece of 12 mm silver steel was quickly and temporary glued together with a 2 component epoxy glue.
My automotive valve grinding paste had to do the job.
At the moment everything seems to be fitted very well but with the wrong bolts, these at the flywheel in the lathe do have the wrong, to big, head.
I will let it like this for some days and will try to swap the bolts step by step without losing any tension hopefully later.
Another very good issue, the ground check from the ignition box to all spark plugs via the entire engine with most of the gaskets in was positive.
« Reply #557 on: May 25, 2017, 12:40:48 PM »
Hi everybody, another bankholiday in Germany and the final tiling and some grouting is done, not my favourite job.
Always a big mess.
« Reply #558 on: May 25, 2017, 07:41:26 PM »
At least you're moving in the right direction Achim  :ThumbsUp:
Are you planning on a bit of "wear and tear" and other ways of getting some "patina" on those shiny tiles  ;)
« Reply #559 on: May 25, 2017, 08:02:31 PM »
Thanks
Hopefully some splashing oil will do this.
Offline Flyboy Jim
  • Independence, Oregon
« Reply #560 on: May 26, 2017, 04:35:18 AM »
Your tile work looks great Achim!  :ThumbsUp: Adds a lot to the scene.
Sherline 4400 Lathe
Sherline 5400 Mill
« Reply #561 on: May 26, 2017, 04:17:49 PM »
Yes what Jim said; the tile and grout looks very nice!
« Reply #562 on: May 26, 2017, 07:19:06 PM »
Jim, Dave thank you very much.
The last grouting was finished this mornig.
Tomorrow hopefully will be the day, to get the pump, the flywheel, the fuel cell with rack and the water tank back in position.
« Reply #563 on: June 06, 2017, 08:19:11 PM »
I thought it makes sense to add this link
http://www.modelenginemaker.com/index.php/topic,7142.msg150292.html#new
here, because in the other thread is my misharpe and descpition about what could be done wrong hidden.
« Last Edit: June 09, 2017, 07:46:58 PM by fumopuc »
« Reply #564 on: June 11, 2017, 03:24:18 PM »
Hi everybody, all lip seals are in position now.
The engine is again driven by the e-motor for another 5 hours with the same power input and revs like before the disassembling.
As Doug Kelley recommended, I have made a pressure test unit to check the pressure under compression. This will be done next.
The short adapter was nice to fit without removing the fuel cell rack.
Unfortunately I have done the measurement without the inlet manifold in place, which has caused a collision with the housing of the pressure gage.
So a longer one was made and I will have to remove the fuel cell with its rack for the compression test.
An adjustable timing wheel is also prepared in the meantime.
« Reply #565 on: June 11, 2017, 05:56:07 PM »
 :ThumbsUp:
Can't wait to see it run.
« Reply #566 on: June 11, 2017, 07:29:30 PM »
:ThumbsUp:
Hi Vince, me too.
But I think there it is still a piece of way to go.
« Reply #567 on: June 12, 2017, 12:00:04 PM »
Some more good progress  :ThumbsUp:  :ThumbsUp: I'm still following along and awaiting the first pops and bangs  :wine1:
« Reply #568 on: June 12, 2017, 12:20:33 PM »
Thanks Roger.
... may be "banging" my head against a wall, because it doesn`t work the way like expected.
The pressure test, with all valve cages in position, will give more information, hopefully next weekend.
Thanks Roger
« Reply #569 on: June 19, 2017, 12:27:37 PM »
Hi everybody.
Last weekend I have done the timing in accordance to the intructions of Doug Kelley.
I took the opportunity to catch a bit more of the driven motion in a video.
<a href="https://www.youtube.com/watch?v=W1OTz-MJgnY" target="_blank">http://www.youtube.com/watch?v=W1OTz-MJgnY</a>
If this thing will ever run, perhaps, nobody will see this beatiful smooth motion anymore.
« Last Edit: June 19, 2017, 01:44:33 PM by fumopuc »
