Author Topic: Micro lathe refurb  (Read 27491 times)
Offline Johnb
  • John Browning, IDSME
Re: Micro lathe refurb
« Reply #60 on: December 12, 2014, 11:26:55 PM »
Nice job Rod.
One thing I've recently done with my Cowells is to do away with the weight of the motor proving tension alone. I've taken Jo's idea of holding the motor stationary against a spring. This improved the finish I've been getting noticeably.
« Reply #61 on: December 12, 2014, 11:53:23 PM »
Outstanding job on the lathe Rod and just love the addition of the DRO'S.
DON
Offline ths
Micro lathe refurb
« Reply #62 on: December 13, 2014, 11:10:12 AM »
Thumbs up for the DRO setup, but the whole project seems to have been a very worthwhile one. I can't recall, but did you make a collet chuck for it? Nice one to have finished by Christmas.
Cheers, Hugh.
nevadablue
« Reply #63 on: July 10, 2015, 11:55:21 PM »
I know this an old thread, but I just had to congratulate you on the fine job of refurbishing the lathe and documenting it. Very enjoyable, THANKS! I got several ideas for one of my projects.
Offline Allen Smithee
  • Mordor, Middle Earth
« Reply #64 on: July 12, 2015, 05:34:05 PM »
I have just returned from visiting an old friend who has an old example of what appears to be this same lathe (but with a "zyto"? brand) which will soon be looking for a new owner. I didn't pay it that much attention, but it's painted a cream colour, and definitely has that helical-gear-driven leadscrew arrangement shown on this flexspeed. It had a tailstock and compound topslide.
If anyone is interested then let me know and I'll put you in touch. It's located on the Surrey/Hants border.
AS
Offline tangler
  • Christchurch, UK
« Reply #65 on: July 12, 2015, 06:01:45 PM »
http://www.lathes.co.uk/zyto/index.html
Bottom of the page.  Zyto was a brand name of Tyzack, the well known, at the time, tool factor.  Lots of badge engineering.
Rod
« Reply #66 on: July 13, 2015, 08:26:04 AM »
The one I mentioned is now on HWS at £30
AS
Online Twizseven
« Reply #67 on: July 13, 2015, 10:51:45 PM »
Rod, I somehow missed this addition of the dro's to the flexiispeed. Looks very good.   I wouldn't mind seeing a couple of closeup photos of the brackets you have fabricated.  Having recently fitted dro's to my cowells mill I quite fancy them on the cowells me90 lathe. I did use the magnetic read heads from machine-dro and use the yuristoys android app and his electronic design for the controller. I can use this for the lathe as well if I use the same readheads and magnetic scales.
Colin
Offline tangler
  • Christchurch, UK
« Reply #68 on: July 14, 2015, 11:50:15 AM »
nevadablue - Nice to to know the posts have been useful.
Colin - Here's a few more pics, hope you find them of use:
Cheers,
Rod
« Reply #69 on: July 14, 2015, 02:27:43 PM »
Haven't had a chance to comment Tangler,  but nicely done!
Online Twizseven
« Reply #70 on: July 14, 2015, 07:49:19 PM »
Rod,
Many thanks for the photos.  That's given me confirmation of some of the ideas I had in mind.  I'm not sure whether its an optical illusion or not but there looks to be more depth of metal on the saddle compared to the Cowells ME90.  How many adjustment screws are there for the saddle gib.  I was thinking I had three, but it may be the one in the middle is to lock the saddle.  Do you have the third screw or have you removed it and the hole is it covered by your bracket.  I would need to leave a small hole in centre of the bracket for an allen key to lock the saddle.  One advantage of the magnetic read heads is that I would not require the covers over the scales, which might simplify things a little.  Both the scales and read head are fully sealed
The image below shows the brackets I made for the mill.
Hopefully I can make something similar.
Thanks,
Colin
« Last Edit: July 14, 2015, 07:55:04 PM by Twizseven »
