The other bit you want to know what you are using is the conrod which will need HE15 or 2014 not a suitable lump of something likely
whats EN25 when its at home
Corrected the typo .Quote from: Jasonb on August 18, 2014, 01:17:41 PMThe other bit you want to know what you are using is the conrod which will need HE15 or 2014 not a suitable lump of something likely As all the stuff I have is best flight grade Durallium I suspect it will be ok Jo
Not seen it done that way before, most people turn the main shaft first and then just hold by that in a keats plate or similar homemade jig to turn the pin/form pin hole, far easier than working between two webs an no need to drill pairs of ctrs at each end of the bar.
What steel did you decide on in the end?
