Steve,Speaking for the great unwashed novice solderers, love to see how you solder those joints.Keep up the good work.Mosey
Hey Steve,You might want to consider powder coating that frame when your done.....I know someone.... Dave
Then the heat is applied with a torch and I use plumbing solder that melts somewhere between 400 - 500 F. I would have to go look for the exact heat.
