Author Topic: Elmer's 25 by AOG  (Read 7350 times)
Online AOG
Elmer's 25 by AOG
« on: August 02, 2014, 02:53:07 AM »
It's been a while since I have built anything and now it's time. I have built multiple mechanics kits and machined a few wobblers and one of the elderberry engines. Since I'm rusty I figured I would start with the classic Elmer's 25. This will be my first build log as well as my first attempt to use Tapatalk to post. So let's begin.
Base and frame cut out.
Marked out
Using my laser to center on the marked out holes
Drilling the radius on the frame
Sawing and filing to shape on my die filer
Online AOG
Re: Elmer's 25 by AOG
« Reply #1 on: August 02, 2014, 02:57:09 AM »
It looks like I double posted the first picture. The second picture should be
AOG
Online AOG
Elmer's 25 by AOG
« Reply #2 on: August 02, 2014, 05:35:52 AM »
Ok here's part 2
Drilling the holes
Drilling for the base
Then I made the alignment pin for the port jig and the port jig.
Transfer punching the port holes onto the frame. I actually made a mistake here and marked the ports on the wrong side. Thankfully I noticed it before I drilled the intake port.
Picking up my marks with the laser prior to drilling. The drilling picture didn't come out so I'm not including it.
Turning the crank disk
Reaming the crank disk after drilling.
After parting off I screwed the disk down to my sacrificial plate and milled the crank
After some filing I pressed the crank shaft and pin into the crank. Next time I will start the cylinder.
« Last Edit: August 02, 2014, 05:39:49 AM by AOG »
Offline Marinus
  • Limpopo, South Africa
« Reply #3 on: August 02, 2014, 08:36:02 AM »
That looks great AOG. Can't wait for the next update
Kind regards
Marinus Kruger
« Reply #4 on: August 02, 2014, 10:37:37 AM »
Nice start on the #25 Anthony. Tapatalk seems to work well so far too.
Online AOG
« Reply #5 on: August 02, 2014, 02:27:50 PM »
I decided to try Tapatalk because of their integrated image hosting.  I don't like the look of uploaded images and the whole photobucket thing seams like a pain. The only downside is that after a limited number of uploads you have to pay to upgrade the photo storage. It's only a couple of bucks so I figured I would try it. So far so good.
Tony
Offline Alan Haisley
« Reply #6 on: August 02, 2014, 04:00:31 PM »
Nice start, Tony. Waiting with   :popcorn: for the next episode.
Alan
Offline arnoldb
  • Windhoek, Namibia
« Reply #7 on: August 02, 2014, 06:18:04 PM »
Good going Tony  :ThumbsUp:
The #25 is a fun engine to build!
Kind regards, Arnold
Online AOG
« Reply #8 on: August 03, 2014, 06:59:38 PM »
Part 3
I have to say this was not a very good shop session.  It started off well enough. I decided I would make the cylinder.
Squareing up the blank
Blank centered up in the four jaw and being faced.
Offset put in and drilling the piece. And then
Disaster
Behold the results of the failure to properly count turns. We have breakthrough.  After stretching the bounds of the English language and a long break I remade the part.
Reaming the bore
Turning the bottom of the cylinder. By this time I had had enough of mister four jaw and decided to complete the other operations on the mill.
This is a picture of the blank after turning. You will notice the scrape marks on the sides. This is from a certain idiot failing to protect the part in the four jaw chuck and then sliding it all around to set up for an offset turn. Thankfully it's nothing taking a few thousands off can't fix. Anyway on with the build.
Finding the edge of the part.
Putting in the recess with an end mill
Drilling the pivot hole. I used the technique that I read from arnoldb's build of turning up an aluminum rod that fits in the bore and then drilling down into it to prevent deforming the edge of the hole. I will use the tool again when I solder the pin. I will end with a family shot (including fixtures and tools)
« Reply #9 on: August 03, 2014, 07:20:34 PM »
looking good  :ThumbsUp:  :ThumbsUp: it's not an engine that I know (but there again I don't know many), do you have a picture/GA of it?
Online AOG
« Reply #10 on: August 05, 2014, 02:37:40 AM »
Here is a video from arnoldb's build of the 25:
<a href="https://www.youtube.com/watch?v=sNlhquZCAWk" target="_blank">http://www.youtube.com/watch?v=sNlhquZCAWk</a>
Tony
« Reply #11 on: August 05, 2014, 12:34:10 PM »
You are coming along well Tony, looks like just a few more parts to go now.
« Reply #12 on: August 05, 2014, 06:09:40 PM »
Indeed it's a neat looking little engine  :ThumbsUp:  :ThumbsUp:
Online AOG
« Reply #13 on: August 24, 2014, 11:04:28 PM »
Part 4
I didn't have to work this weekend so I decided to get some shop time in. I started with making the piston rod
Piston rod turned and threaded
Over to the mill and into my new ER 32 collet block to mill the flats
Cutting the piston rod from the parent stock on my die filer with the hack saw blade and over arm.
Piston turned and cutting the oil grooves.
After drilling the center hole I tried to part it off. Unfortunately I can't part brass to save my life so it came off with the hacksaw
Over to the tapping stand to tap a 5-40 thread
With the piston done it was time to use it in the jig in order to transfer punch the location for the cylinder port
Drilling the port. Now it's time to make the hose fitting
Drilling the hose fitting after turning to size
That's it for this weekend. The next step is to lap the frame and the cylinder and get ready to solder in the pivot pin. I also need to find something to make the flywheel from. I will leave you with a family picture.
« Reply #14 on: August 25, 2014, 12:26:57 AM »
Thanks for the update Anthony, you made some good progress today.
