Chuck--Since you have already posted some good pictures of side valve engines, I am going to ask this question here as well as in its own separate thread. I have a question about side valve engines. I have looked at a number of pictures of side valve engines, and they seem to fall into two categories. One is as per the Philip Duclos Gearless engine, where the cylinder is a plain bore separate part and the combustion chamber is actually in the head, which bolts to the top of the cylinder. The valve cages, seats, and housings bolt onto the outside of the head and are connected to the combustion chamber in the head through passages drilled through the sides of the head. The piston does not travel up into the head, but stops flush with the top of the cylinder. T he other type, (and I'm really not sure about this) seem to have a plain bore cylinder, then a separate piece with the combustion chamber and valves buried in it bolted to the top of the cylinder, and then a flat, rather featureless (except for sparkplug hole and cooling fins) head bolted to the top of this intermediate piece.It kind of LOOKS like the piston would have to travel up part way into this intermediate piece, but I just can't imagine a bolted joint that the piston and rings would have to travel over. (see picture) ----Or--is it possible that there is a cast iron liner that fits down through the intermediate piece and the cylinder so the piston can travel all the way without passing over a joint? Who can set me straight on this.----Brian
Brian, your lattest drawings remind me so much of the Briggs engine valve arrangement though there, the junction between the tappets (inside the crankcase) and the valve stems was not open but enclosed in a small chamber presumably to get a bit of splash lubrication from the crankcase. While the springs and retainers were also a tight fit, it was do-able just as it had been done in the prototype. Perhaps the attached cross section views may help in some way.Bill
