Author Topic: Neat gearless valve train design from the Wright Bros.  (Read 11905 times)
Re: Neat gearless valve train design from the Wright Bros.
« Reply #15 on: October 26, 2014, 11:49:47 PM »
That's pretty cool Bill
If you don't mind; I curious how you did the animation?
Offline BillTodd
    • Bill's website
« Reply #16 on: October 27, 2014, 08:45:52 AM »
I use a combination of a 3d modeller and a photo manipulator/ gif editor.
it's really just a typical stop frame process: moving parts to where they should be for each frame . the modeller does some tweening but is ofte more of a hindrance than a help.
bill
Offline BronxFigs
« Reply #17 on: October 27, 2014, 09:17:44 AM »
Bill Todd-
Perfect!  Computer animations are great.  A moving picture is worth a thousand drawings!
Thanks, Myrickman and Bill Todd....for clarifying this simple mechanism.
Frank
QUESTION:
When building this mechanism, what surfaces should be hardened to prevent wearing, if any? .....flipper-cam, follower?
« Last Edit: October 27, 2014, 09:28:41 AM by BronxFigs »
90% of everything is BS!
Offline BronxFigs
« Reply #18 on: October 27, 2014, 09:40:01 AM »
As I am sitting here becoming hypnotized by the demo-video and animated version of this mechanism...some thoughts:
Can valve timing be varied, i.e. advanced, retarded?  How would this be done?  Lobe shape of the flipper-cam?
Is this mechanism only really practical to use for controlling  the exhaust valve on an engine that has an atmospheric intake valve?
Offline BillTodd
    • Bill's website
« Reply #19 on: October 27, 2014, 11:04:19 AM »
I'm working on a design that would operate both valves and have a realistic timing; for instance, a typical cam has a 120° lifting period , this would equate to 240° of the crankshaft. Similarly, the inlet and exhaut cams are typically 90° apart ,to use one crank cam requires followers at 180° ,making it tricky to get the flip mechanism to work.
I think it can be done. I'll post an animation if it works:)
Offline BillTodd
    • Bill's website
« Reply #20 on: October 27, 2014, 07:37:52 PM »
Oh well :(
Doesn't look like a dual follower will work
Here's an animation with a cam of 240 degree duration.
