This was my experience:http://www.modelenginemaker.com/index.php?topic=2866.0
Just a quick note, make sure that your thicker gibs clear the drive gear. Mine had very little clearance.
Sadly the brass I've ordered for the gibs wont be here until at least tuesday, so I will have to think up some other mods to be getting on with in the meantime.
While you have the mill set up, this might be a useful addition http://homepage3.nifty.com/amigos/stopper/stopper-e.htm* Danny M *
If the angular contact bearings are the same size as the standard bearings they will certainly be easier to fit (I suspect that just fitting good quality versions of the standard bearings is probably enough ).
Deep Groove ball bearing 30 x 62 x 16 - Dynamic load rating 19500N; Static load rating 11200NAngular Contact ball bearing 30 x 62 x 16 - Dynamic load rating 23800N; Static load rating 15600NTaper roller bearing 30 x 62 x 17.25 - Dynamic load rating 40200N; Static load rating 44000N
