Author Topic: Building Kozo's New Shay locomotive  (Read 162085 times)
Re: Building Kozo's New Shay locomotive
« Reply #15 on: June 23, 2014, 08:00:47 PM »
That's a nice looking build  :ThumbsUp:  :ThumbsUp: As you say the designer seems to like brass  :)
« Reply #16 on: June 23, 2014, 09:44:19 PM »
I like working in brass too, be nice if I had bought lots more a few years ago before the prices went so high!
« Reply #17 on: June 24, 2014, 02:42:03 AM »
More nice looking parts there...the progress is amazing and I am really enjoying following along on this one.
« Reply #18 on: June 25, 2014, 03:36:04 PM »
Thanks Bill - I've never attempted a project this big before, but Kozo's instructions take you through one little part at a time with very good methods, so I am having fun with it.
« Reply #19 on: June 25, 2014, 03:42:08 PM »
Couple rainy days, so good time to play back in the shop! Got the rest of the boiler support brackets done this morning.
I am trying another way of hosting the images, hope they come through okay...
The adjustment plates and the rod end plates were gang drilled
and milled
from longer pieces to make it easy to hold/align in the machine vise,
then cut apart and trimmed to final length
before soldering onto the rods on the brackets
and the rod ends
before assembly onto the model.
It is starting to look like a loco, little by little!
Next up are the angled brackets at the ends of the main rails - those look like they will be tricky, getting all the angles in the right directions....
« Reply #20 on: June 26, 2014, 12:35:32 AM »
Nice to see those Sherlines in the background :) Another day of good progress too and yes!! it is starting to look like a loco :)
Offline PStechPaul
  • Cockeysville, MD 21030
« Reply #21 on: June 26, 2014, 03:04:25 AM »
The images are hosted on the Home Model Engine Machinist site and might be blocked by this site to protect against cross-site scripting.
I tried loading the URL of the first image but it said it required a log-in:
http://www.homemodelenginemachinist.com/attachments/f31/70530d1403706350-building-kozos-new-shay-locomotive-img_4123.jpg
« Reply #22 on: June 26, 2014, 07:14:35 AM »
Paul, Just wrap it with the normal [ img ] .....[ /img ] and it works fine:
Offline PStechPaul
« Reply #23 on: June 26, 2014, 07:19:40 AM »
Not for me. I just see a little box with an "X". Maybe you are a member of the Home Model Engine Machinist forum, and are logged in?
« Reply #24 on: June 26, 2014, 08:07:22 AM »
Now I'm getting boxes with X's, it was ok just now  :headscratch:.
Went over there and logged in, came back and still boxes with Xs in them  :shrug:
« Reply #25 on: June 26, 2014, 03:14:52 PM »
Okay - it was worth the try to cross link them that way, guess it was not a great idea. The photos are attached to the post in the normal way too so you can see the same shots that way, just not in line with the text. I'll go back to the normal attach way from now on.
« Reply #26 on: June 26, 2014, 03:15:57 PM »
Yeah - a small machine CAN turn out a big project!
« Reply #27 on: June 28, 2014, 11:06:39 PM »
Kinda surprised myself how quickly this part of the build has gone - the main frame is done and ready for paint. A bunch of days I got going back in the shop, until looking up at the clock and going 'WHAT time is it??'. Sure ign of a fun project! Most of the parts so far are nice easy square shapes, but LOTS of little holes to tap....
Most recent parts were the angle braces at the ends, which have lots of odd compound angles to drill/solder at, fortunately Kozo gives detailed measurements for the parts and the soldering jigs, so they came together well.
After that was a set of floorboard brackets, simple blocks, angled on bottom, and drilled using the template made at the start so they all fit perfectly (the jigs for multiple part drilling were well worth the time to make).
Then, it was down to the floorboards - to drill the holes for those I put the whole frame up on the mill table, you can just see the low-tech machinists jack at the far end (two carriage bolts/nuts holding a crossbar) to support it during drilling.
Once all the holes were drilled at tap size, the boards were pulled off and drilled/countersunk for the flat head screws used to hold them on.
Ready for paint now, got some hi-temp paint that I need to test in the sprayer...
« Reply #28 on: June 29, 2014, 03:08:12 AM »
Its beautiful crueby!! What is the overall length of the frame?
« Reply #29 on: June 29, 2014, 10:19:44 AM »
I like that mill set up! :ThumbsUp:
Very creative!   Should work just fine, and pushes the limit of a small mill!
