Author Topic: Building the Benson Vertical Steam Engine  (Read 93895 times)
« on: May 21, 2014, 11:46:52 PM »
Today is my start at building engines again.   :cartwheel: I have spent almost two years making tools, not complaining mind you. Making tools is as satisfying as making engines and helps a lot with making engines. I have had this engine on the back burner every since I followed Jason making his. It's a beautiful and elegantly designed engine and more of a show case model. So this will be my attempt to capture its beauty and hopefully do it justice.
Ok I started by making a few parts starting with the base and it's flanges. Tomorrow if I get a chance I will be doing the column.
This first photo is a flange plate that the column will mount to and the pump.
Rounding the edges on the rounding table.
Tapping the holes after drilling on the UPT.
And I guess you will be upset with me because in the process of making the base I failed to take photos of the process. I cut the base out on the band saw after laying it out on a piece of corain.and smoothed the edges on the die filer. Then used a file and sand paper to smooth it enough to route it. Below is a photo of the flange and base complete.
That's all I have for today and thanks for looking.
Re: Building the Benson Vertical Steam Engine
« Reply #1 on: May 22, 2014, 12:12:55 AM »
Great start Don, count me in for the ride :)
« Reply #2 on: May 22, 2014, 12:34:36 AM »
Pulling up a chair Don  :popcornsmall:
Looking forward to watching this one take shape.
« Reply #3 on: May 22, 2014, 12:46:38 AM »
Me too!  I'll be watching your build progress!    :popcorn:
« Reply #4 on: May 22, 2014, 05:35:24 AM »
Hi Don, that is a good start. Looking nicely. I will follow.
Offline cfellows
« Reply #5 on: May 22, 2014, 05:45:42 AM »
Looks like it's going to be a beauty, Don.  The Benson is one of my favorites.
Chuck
Online sco
« Reply #6 on: May 22, 2014, 06:36:03 AM »
Not seen a Benson build before so will be watching intently!
Simon.
Ars longa, vita brevis.
« Reply #7 on: May 22, 2014, 07:37:44 AM »
Looking good so far, seems like you have opted to keep it at the original size.
Simon, this is my build, click the links for the various parts. Also shows anyone who wants to try it how the corian base is done.
« Last Edit: May 22, 2014, 09:56:32 AM by Jasonb »
Online sco
« Reply #8 on: May 22, 2014, 08:01:50 AM »
Thanks Jason.
Love this quote from the Nottingham Daily Express - "....it was inspected by many practical men, who expressed their unqualified admiration for it'  ;D
Simon.
Offline swilliams
  • Canberra Australia
« Reply #9 on: May 22, 2014, 08:32:26 AM »
Offline Robert Hornby
  • Terrigal NSW Australia
« Reply #10 on: May 22, 2014, 08:58:42 AM »
Don, very nice start to a beautiful engine, I will be watching closely and it will be top of my list for a build after the boat.
Robert
« Reply #11 on: May 22, 2014, 12:06:46 PM »
Good going Don.  I will be watching you progress as you move along.
« Reply #12 on: May 23, 2014, 12:07:37 AM »
Guys thanks for following along, I will need the support.
Yes I prefer to keep it the same size.  I don't think I could do a bigger flywheel in my lathe. Jason I hope you kept me straight, if you know I am on the wrong track building it.
Today was a good day and I started and finished the column. I also made a start on the entablature. I am trying to decide if I should pin or screw the entablature together for soldering. I guess I will decide when I cross that road.
Ok the first photo I set a 6" x 1.5" piece of brass into the three jaw chuck and used the steady to hold the end for facing and drilling each end to .312".
After marking the points with the warner parting tool, I set the compound slide to 2 degrees to cut the tapers.
After cutting the taper I need to make a profile tool to cut profiles on the column. I set a piece of tool steel in the vise and cut the end with a 10 degree relief and used a .1875 slot drill to one end and a .156" on the other end.
The finished profile too after Harding it.
Finishing the columns profiles with the new tool.
Doing some profiling with a graver and my Quick change tool rest
Parting of the column and I used a piece of 5/16" cold roll in the chuck to support it once parted.
 I moved the column to the mill to drill the top holes that will secured the entablature after finding center and using the DRO function for the six holes.
Next I mounted the angle plate to the mill to mount the column horizontal to mill the face of the column pump bracket will bolt to.
Found center and edge of column and drill the pump bracket mounting holes.
With the column finished I started making the entablature parts. I first started with the bottom base flange on the lathe. While on the lathe I set up my Foredom to drill the mounting holes on the flange. I spotted the center with a spot drill and found center, dial in the dimensions. Using my Dividing attachment to get the six hole patterns.
I made the sides and bearing mounting brackets. Cut the sides on the bandsaw a filed then to shape. This photos shows the parts made so far. I still need to drill holes in the side pieces and cut slots into the entablature flange for silver soldering.
That's it for today and thanks for looking.
« Reply #13 on: May 23, 2014, 12:13:15 AM »
You got a lot done today Don!! Beautiful work on the column and a very nice write up too along with the pictures. You are on a roll with this one :)
« Reply #14 on: May 23, 2014, 01:39:52 AM »
Nice work Don!
The Column turned out real nice, did you harden the profile tool?
Oops I see where you did harden it :facepalm:
