Today I was center drilling a piece in the lathe. As seems to
happen far too often with me, the center drill tip broke off in the work.
I swore out loud, but I had some hope. Just a couple of days ago I had read a
tip in a book about how to remove the broken tip from the workpiece.
I decided to try the idea, and it worked!
The remainder of the broken drill was modified with a Dremel abrasive cutoff
disk. A center section as wide as the broken off tip was ground away leaving
cutting edges only in the area surrounding the tip (see the photo).
The idea is that the modified drill will cut away the material around the
broken tip without touching the tip itself. When enough of the surrounding
material is removed, the broken tip simply falls out.
I hope the photo is clear enough.
Again, I take no credit for the idea, I saw it in a book.
