Author Topic: V-belt pulley question  (Read 2338 times)
Offline sshire
    • LS Editions
« on: April 24, 2014, 02:15:05 PM »
After seeing Chuck's post about the Gates Polyflex v-belts, I decided to go with those on the PMR Dynamo instead of a flat belt and a crowned pulley.
The spec for the 3mm belt shows it is a 60° angle so I did a little trig to calculate the depth of cut for the 60° tool to give a 3mm opening at the top.
The question is:
Is there a convention for how far below the pulley top surface the belt should be recessed?
Best,
Stan
Offline Mosey
  • Rosemont, New Jersey, USA
Re: V-belt pulley question
« Reply #1 on: April 24, 2014, 02:31:56 PM »
Stan, There are industry standards for belts/pulleys, 3L, 4L, etc., dependent on the belt width. The dimensions follow those standards found on the pulley websites.
Mosey
Offline Dan Rowe
  • Dripping Springs TX USA
« Reply #2 on: April 24, 2014, 02:56:30 PM »
Stan,
See page 39 of this link for a drawing of the pulley cross section for Gates polyflex belts.
http://www.klee.dk/files/cms/services/kataloger/gatesvedl.pdf
I just noticed it only has the dimensions for the 5M, 7M and 11M sizes but that should give you the idea for the 3M size.
Dan
ShaylocoDan
Offline Dan Rowe
« Reply #3 on: April 24, 2014, 04:17:00 PM »
Stan,
Found it see page 99 of this .pdf for the pulley dimensions.
http://www.gates.com/~/media/Files/Gates/Industrial/Power%20Transmission/Manuals/PT_GatesLPPdesignManual_2005.pdf
The 3M profile has a 2/3M and a 3/3M version for a double row and triple row belt for miniature heavy equipment.
Dan
ShaylocoDan
Offline sshire
    • LS Editions
« Reply #4 on: April 24, 2014, 04:29:59 PM »
Dan
Thanks so much. That's exactly what I needed. I had looked on the Gates site but never found it.
Best,
Stan
