Chuck,That looks business-like! Are you sure that clamping ring will have enough grip to cope with the cutting loads without slipping?Simon.
Looks good from here Chuck, just don't forget to take a video of it in action.Don
Hey Chuck,Do yourself a favor and put a couple of drip oilers in, or conversely, a vertical feed pipe with a bit of felt wicking. Either way will feed a little oil all the time to the bearings, and they will last a lot longer and run a lot cooler with a little oil all the time. Looks good man...Can't wait to see it in action. Dave
Looks good. Is there a reason for the extra hole(s) in the box tube Chuck?
Very cool Chuck.You seem very pleased as you should be.What kind of cutter is that? I'd like to look it up.
