Author Topic: MEM Member Map  (Read 85153 times)
Offline bp
  • Adelaide, SA
Re: MEM Member Map
« Reply #45 on: April 09, 2014, 03:25:45 AM »
I'm in too.  Put my marker somewhere in the city,
cheers
Offline gldavison
  • Tarkio, Mo.
Re: MEM Member Map
« Reply #46 on: April 09, 2014, 03:42:22 AM »
Got mine on there.
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
Offline RMO
  • Rexburg, Idaho, USA
Re: MEM Member Map
« Reply #47 on: April 09, 2014, 03:53:17 AM »
I'm in as well.
Online AOG
Re: MEM Member Map
« Reply #48 on: April 09, 2014, 04:39:58 AM »
I'm on
Re: MEM Member Map
« Reply #49 on: April 09, 2014, 06:20:20 AM »
I am in now too. The lonely blue flag in the middle of good old Europe.
Offline Giraldus
Re: MEM Member Map
« Reply #50 on: April 09, 2014, 08:16:57 AM »
Hi Achim,
now I stepped in too - you're no longer lonely  ;)
So long
Gerd
Offline spuddevans
  • Portadown, Northern Ireland
    • My photo website
Re: MEM Member Map
« Reply #51 on: April 09, 2014, 08:38:01 AM »
Me too
Tim
Measure with a Micrometer, mark with chalk, cut with an axe. MI0TME
Offline gadabout
Re: MEM Member Map
« Reply #52 on: April 09, 2014, 09:00:12 AM »
I'm the orange (and only) one in Tasmania
cheers
Mark
Offline tel
  • Bathurst District, NSW, Oz.
Re: MEM Member Map
« Reply #53 on: April 09, 2014, 09:40:25 AM »
... and I'm the blue button in NSW
Offline michaelr
Re: MEM Member Map
« Reply #54 on: April 09, 2014, 09:41:32 AM »
I'm in, but how do I delete a (my) misplaced marker.  :facepalm2:
Re: MEM Member Map
« Reply #55 on: April 09, 2014, 10:57:21 AM »
Me too! It's getting positively crowded down here!
Offline Nicolas
Re: MEM Member Map
« Reply #56 on: April 09, 2014, 11:42:50 AM »
I'm on now too, my pin landed straight on a cafe.
If you click on your pin a small window should come up. At the bottom right of that you can either click 'displace', 'relocate' or 'trash'
Nicolas
« Last Edit: April 09, 2014, 11:46:36 AM by Nicolas »
Offline Ramon Wilson
  • Suffolk in the UK
Re: MEM Member Map
« Reply #57 on: April 09, 2014, 12:00:39 PM »
I would be in if I could  ::) After several attempts over two days just keep getting the same result
I've registered and click on 'simple addition'. Filled in the relevant details then on 'Submit' get a enter key or password - is that different to the password when registering if so 'where the hell is it!'
It says 'or click on map' if I hover over UK I get a pointer telling me who's already 'in' or a hand to pan the map.
Awww - how I hate these bloody things at times
Can anyone help
Ramon
Re: MEM Member Map
« Reply #58 on: April 09, 2014, 12:08:40 PM »
Hi Ramon,
I had the same problem. The following from Stan did it for me...(bears repeating as it gets lost with all the replies)
Sorry. The password (key)is mapmem. No need to register or sign in. It asks for the key when you add a marker/pin.
Go to Additions->Add Marker Simple.
Type in 'mapmem' for the key.
Anything in the name field (like Ramon).
General location (city, country) or use that 'click on the map'.
Press 'submit'
Hope that helps.
Offline sshire
    • LS Editions
Re: MEM Member Map
« Reply #59 on: April 09, 2014, 12:11:14 PM »
Ramon
When you get the entry box for adding a simple marker, it has a space for a key/password. Enter "mapmem" there, then your name and location and it should work.
If it doesn't, let me know.
Best,
Stan
