Thanks for the compliment Arnold , although if you could see my work up close I wouldn't say its well done!
on with the big & little ends
for the big end I followed the usual road of squaring up 2 pieces of bronze and soldering them together.
I marked the centre for the bore , centre popped it, then centred in the four-jaw.
after drilling and boring I then transfered it to a split Ramon mandrel and turned the outer lip.
rather than file the outer edges round, I decided to drill the ends, hacksaw and file back, then solder in pre-drilled ferrules with a base - so much neater than filing
for the little ends I tried a different tack.
I made a fixture for the face plate to help in boring out this type of bearing, but it can be a pain trying to get the bearing spot on the lathe centre line , especially if the bearing has been machined to it's finished width - you then have to bore it out spot on centre.
so , I soldered some scrap pieces of bronze that where the right thickness, but over length, together
I then set up the faceplate fixture to the right height.
I have pieces of tube turned down to various thicknesses to give the required offset. the 6.0mm refers to how much the fixture is below lathe centre height.
the important point to bear in mind is not how accurate the 6mm offset is , but that once the plate is fixed in position , all bearings fitted to it will be bored out at the same height in relation to thier base - so long as you remember to mark the lower half so you know which way they went onto the fixture!
it's then a case of drilling and boring to size
once that's done , well I'm becoming a big fan of Ramons mandrels
I then filed the outside edges down to the right size in relation to the bore. measuring much like I measured for the main bearings.
To drill for the clamp bolt holes, rather than scribe a centre line, I turned up a small bush whose diameter is the same as the thickness of the bearings.
I then used a small marking punch to centre pop the hole positions. I have a number of these, all turned down to various diameters that correspond to BA diameters.
Ideal for spotting thru' pre drilled components.
then it's a case of drilling them
heating up to split the two halves and soldering on a base. For small components, I find a small 'lazy bird' is better than trying to clamp them together.
and here is a cleaned up big end next to a small end just soldered
now for the con rods themselves
thanks for looking
peter
