The Silver Bullet is complete enough to run. It has gas in the tank up to the carburetor, sparks at the plugs, and the timing is as Steve H. suggested. I can crank it over with a hand crank through about 1/2 rotation. It does not give a pop.What should I do to get it to start?Mosey
Hi Mosey, I see no problem reversing the leads to get proper rotation. I have a hobby starter myself that I had for a helicopter I use to have. Don
My Sullivan R/C starter turns CCW, and my engine, CW. Can I assume it is OK to reverse the power leads from the battery and run it backwards?Mosey
