Author Topic: Quick 'n dirty Box Tool  (Read 3414 times)
Offline arnoldb
  • Windhoek, Namibia
« on: March 30, 2014, 07:59:43 PM »
I'm still making studs for the Corliss... but going has been tough with the 3mm stainless rod I have.  Half the studs have had threads ruined by trying to get a tight enough grip to cut the opposing threads - so I got to a point where I decided to measure things a bit.  I don't get split die nuts here in Windhoek - so have to use the ones I can get as-is.  Measuring over a threaded section I cut with the die nut, I found that the nut brings the overall diameter on the threaded section down to about 2.9mm for M3, and that the stock I have been using is a bit over-size at just about 3.1mm.
So, thus far, the die nut's had to remove a lot of unnecessary stock just to cut threads - hence the forces required.
To make life easier, I decided it would be nice to turn down the stock a bit - if I turned it down to 2.9mm, life would become significantly easier for the threading operations.  And I needed fairly long sections of 3mm stock turned down.  The easiest way to do this is with a box tool to prevent flex.  Tel's many times showed his and I've often thought "That would be handy for this job".  So, time to make a tool...
I sat down for a couple of minutes and thought things through a bit, and looked around for suitable stock.  As usual, nothing suitable was to be found, so I raided the off-cut bin for bits to fabricate it from, and came up with a section of 6mm flat bar and a 12mm bar end.  I'd decided to make the tool for 4mm square HSS toolbits; I have a lot of those as I buy them about 5 at a time - they are fairly cheap and quick to grind to any required shape - ideal for the way I go about things in my shop:
First I milled a 4mm slot about 6mm deep and about 3mm from the edge of the 12mm bar.  The wider edge will be left to clamp in the toolpost:
Using a bit of 4mm HSS that had a nice edge and had not been ground down on the top, I scribed a matching line on both sides of the bit of 6mm bar with the workpieces lying on my "glass surface plate":
That will become the center line for the hole that will take insert bushings.
Then I ground a generous chamfer on both the top and bottom sides of the 12mm block - this is for welding the 6mm block to it:
The bits were clamped together while on the surface plate with a toolmaker's clamp:
And off to some of my crude stick-welding  :embarassed: - bottom first:
Then the top - trying to do a half-decent job and not getting any weld into the milled groove:
Things would have gone a lot better if I had thinner welding rods - but I'm out of stock on that, so the welds were globbed on with 2.5mm rods...
Back to the mill, and I picked up the center line scribed earlier and drilled out to 9.8mm:
That was then reamed 10mm.
Three 3.3mm holes to tap M4 followed - these are for securing the toolbit:
A 2.5mm hole to tap M3 followed from the back end into the groove.  I chose M3 for this as it very conveniently has a 0.5mm pitch, meaning it's fairly easy to use it to approximate in-feeds; a full turn of the adjustment screw will give 0.5mm infeed - resulting in a 1mm diameter reduction in workpieces:
Another hole was drilled and tapped M3 for a grub/set screw to retain the insert bushes - and after tapping all the holes and finding suitable screws, I ended up with this crude bit of tooling:
I had to give it a test-run, so I turned up a bush with a 3.1mm hole to fit the offending stainless stock, mounted that, ground and honed up a bit of HSS and proceeded to turn a 150mm length of the offending over-size stainless down to 2.9mm - That was easy-peasy with a nice consistent size along the length and a good surface finish:
I'll have to tidy the tool up a bit at some point - it's a long time since I've made such a cruddy-looking piece of tooling.  For now it works just fine.  I took a bit of care to make it work with standard toolbits - at a height that's already centered.  That's not a biggie though - for non-standard toolbits, it's easy enough to turn the insert-bushes with the guide hole slightly eccentric - then the height can be adjusted by rotating the bush.  As an added bonus, it will work on both my lathes  :)
After making another couple of studs, the going was definitely easier - but not quite as easy as it should be, so I think my 3mm die nut has seen the back end of its sharp days.  I'll get a new one in the coming week, and at some point also have a go at sharpening the blunt one, as it's a fairly high quality German bit of tooling that I'd rather not just toss in the bin.  I might even slit it with a Dremel cut-off wheel and see how it will work as a split die afterward.
Kind regards, Arnold
Offline sshire
    • LS Editions
Re: Quick 'n dirty Box Tool
« Reply #1 on: March 30, 2014, 09:30:28 PM »
Pretty can come later. It looks like it works as advertised. Simple and effective. A few passes over the welds on the mill should sort out the offending material. As soon as Cabin Fever is finished this will be the first project. I have a few micrometer heads which I'm now contemplating as a precision tool advance mechanism. I just can't leave well enough alone.
Do you think that a live center at the tailstock would be necessary?
Best,
Stan
Offline Johnb
  • John Browning, IDSME
« Reply #2 on: March 30, 2014, 09:35:34 PM »
I like that!
Offline Thayer
  • Connecticut, USA
« Reply #3 on: March 30, 2014, 11:55:21 PM »
Nicely done Arnold!  I'm wondering, how does one go about sharpening a die?
Thayer
« Reply #4 on: March 31, 2014, 12:10:34 AM »
That's so Arnold.  ;D
Offline arnoldb
  • Windhoek, Namibia
« Reply #5 on: March 31, 2014, 03:37:34 PM »
Thanks for checking in Gents :)
Stan, it can of course be modified and improved  :ThumbsUp: .  I wouldn't suggest a live center in the tailstock for very long thin sections, as that puts the workpiece under tension and it will buckle easily.  A bush with a matching hole, gripped in a tailstock chuck might be a better option - or a revolving tailstock chuck.  As always, there are limits as to what can be done and one must remain within sensible speeds as well.  If a long thin workpiece goes out of whack, it will immediately bend and start slapping around...  So like all machine work, a dose of good sense is essential.
Thayer, I haven't tried sharpening dies yet, but it should be possible to use a small cylindrical stone in a rotary tool (Dremel etc) to sharpen up the cutting edges.  It would best be done with a jig to control things fairly accurately.  Removing too much material will weaken the die's teeth though, so the amount of sharpening one can do will be limited...
I hope that's a good thing  ;)
Database Error
Back
