I am in the process of making up some special tool holders for a dikson tool post
I have made these before and the wedge part is well sorted .
So one of these is to take a 5/16 parting blade , you can buy the half inch ones and the 5/16 are available for the rear post, the rear one will not fit it fouls the top slide .
So out came the measuring equipment the blade is 1.5 mm thick at the top and 1.0 mm at the bottom , now I have measured both my purchased half inch ones the blocks, and the back face is flat no taper so the blade leans over with one side vertical and the other with the total relief showing.
So do I leave a small register at the bottom of 0.25 mm thick to make the blade stand upright with the relief on both sides or not
I need to use this blade in the front position for brass but it will be ok for steel
I have seen the holders for these blades to go in the tool holder but they are to bulky and the stick out is to much
