Author Topic: Piston Stroke to Bore ratio for steam Engine  (Read 4381 times)
Offline BaronJ
  • Grumpy Old Git !
« on: March 23, 2014, 04:43:46 PM »
Hi Guys,
What would be the best piston stroke to bore ratio for a double acting stationary steam engine ?
I am thinking of using a cast iron cylinder with a 20 mm bore but have no idea what length to make it for optimum performance.
Best Regards:  Baron.
I don’t regret the things I’ve done, I regret the things I didn’t do when I had the chance.
Offline Tin Falcon
  • Down Jersey USA
Re: Piston Stroke to Bore ratio for steam Engine
« Reply #1 on: March 23, 2014, 07:38:27 PM »
There are lots of stationary engine designs.
Depends on if you want the engine to run fast or slow.
1:1 ratio or square as it is called is IMHO the most common.
so 20 mm bore 20 mm stroke  or 10 mm ctc crank shaft center to crank pin center.
if you are building a waling beam they tend to have a longer stroke in the 1:1.25 to 1:1.5 range.
Tin
Offline sbwhart
  • Live Long and Prosper
« Reply #2 on: March 23, 2014, 07:52:38 PM »
Small engines tend to run fast so I  usually use a 2-1 or 2.5-1 ratio boreu 20mm stroke 40 or bore 20mm stroke 50mm
Stew
Offline BaronJ
  • Grumpy Old Git !
« Reply #3 on: March 23, 2014, 08:46:27 PM »
Hi Tin, Stew,
Thanks for your reply's.
So based on your suggestions, if I go for a stroke length of 30 mm with a 5 mm thick piston I shouldn't be too far out.
I'm thinking marine type engine here with four cylinders.
