Author Topic: Added flat belt pully to my Odds And Ends engine.  (Read 3465 times)
Offline Doc
  • USA ND
« on: March 23, 2014, 01:20:09 AM »
Added a flat belt pulley and a tapered hub mount today. Thinking of building something for it to power like a buzz saw. This was my first IC engine I built back about 25 years ago and is still a nice running engine.
Offline cfellows
Re: Added flat belt pully to my Odds And Ends engine.
« Reply #1 on: March 23, 2014, 03:47:35 AM »
What will you use for a belt?
Chuck
Offline Ian S C
« Reply #2 on: March 23, 2014, 08:48:20 AM »
Something like a power hacksaw would work ok, you can make one that uses a junor hacksaw blade, or part, or all of a full size blade.  You would just have to scale it to suit the motor.      Ian S C
« Last Edit: March 27, 2014, 12:12:35 PM by Ian S C »
Offline stevehuckss396
  • Sterling Heights, MI
« Reply #3 on: March 23, 2014, 10:56:39 AM »
Aero is pouring parts for an ice cream machine for Ron Ginger.
Offline Doc
  • USA ND
« Reply #4 on: March 23, 2014, 02:58:29 PM »
Chuck I'll have to do some research and see what I can come up with.
Ian & Steve I'm still thinking saw kind of like my grand dad had that we hooked up to the old John Deere. I still have memories of that. I'm hoping some day to build a model John Deere A.
Thanks for the comments!
Offline Doc
  • USA ND
« Reply #5 on: March 23, 2014, 03:15:38 PM »
I just did a little looking and I think I'll take a look into these and see what they look like and if they will work.
Offline cfellows
« Reply #6 on: March 27, 2014, 05:22:48 AM »
It never would have occurred to me that anything like this is even available.  Interesting...
Chuck
« Reply #7 on: March 27, 2014, 12:40:59 PM »
Doc--I have that same engine. It doesn't have enough power to run a small buzz saw---at least not one that will cut real wood. I did use it to run the sawmill that I built with a vertical reciprocating saw blade.--Brian
« Last Edit: March 27, 2014, 04:10:38 PM by Brian Rupnow »
« Reply #8 on: March 27, 2014, 01:07:51 PM »
You will also need a much larger dia pully to work a buzz saw at a decent speed, look at the sizes on this Galloway cross cut saw, which will also reduce the mechanical advantage :(
When they get to that size its easier to make them from tube and fix to the spokes if you don't want a clutch
Offline Doc
  • USA ND
« Reply #9 on: March 27, 2014, 02:15:20 PM »
Strictly for looks not to cut wood just to look at
