Author Topic: reduce engine oscillation????  (Read 1918 times)
Offline burnit0017
« on: March 22, 2014, 10:06:18 AM »
<a href="https://www.youtube.com/watch?v=3J9SEBgoTMY" target="_blank">http://www.youtube.com/watch?v=3J9SEBgoTMY</a>
Hi, I just completed my fist build. Oscillation of the engine is a real problem.  :-\Searching for solutions to remove the problem. Any help received is greatly appreciated.
Re: reduce engine oscillation????
« Reply #1 on: March 22, 2014, 12:05:46 PM »
Bolt it to the table.
Offline arnoldb
  • Windhoek, Namibia
« Reply #2 on: March 22, 2014, 12:56:12 PM »
Bolting it to the table might not be a feasible solution  ;)
The hopping around is caused by the mass of the oscillating parts.  Unfortunately, with your engine configuration, there's no way to properly balance it, but what you can try to reduce the vibration is to lighten things up as far as possible.  For example, cut away any excess metal that's not needed on the big blocks oscillating between the pistons; from what I can see there's quite a bit of material there that's not needed, and adds considerably to the oscillating mass.
Kind regards, Arnold
Offline burnit0017
« Reply #3 on: March 22, 2014, 02:45:25 PM »
<a href="https://www.youtube.com/watch?v=FSSEk2nuVWA" target="_blank">http://www.youtube.com/watch?v=FSSEk2nuVWA</a>
Hi, thanks for the input. I found this project that has a configuration that should solve all the problems. Thanks again for help. Time to start a second build. Cheers.
