Author Topic: Stuart Major Beam Engine  (Read 88936 times)
Offline Chipmaster
Re: Stuart Major Beam Engine
« Reply #105 on: May 24, 2019, 09:49:54 PM »
Hi Chris, like you I've had failures using soft solder. This time I contrived to use a longer silver solder joint for added strength. However, because of the higher temperature involved you have to be careful not to melt or distort delicate brass parts when trying to separate them. I've done that, very frustrating to see a few hours work wrecked in that way.
Andy
Offline Chipmaster
« Reply #106 on: May 27, 2019, 10:49:57 AM »
The next step was to make the pair of brass bushes that fit on the forked ends of the connecting rod.
Fork end bush by Andy, on Flickr
To ensure they matched I machined them together in one sitting.
WP_20190518_15_43_46_Pro by Andy, on Flickr
Milled half the diameter away.
WP_20190518_16_02_08_Pro by Andy, on Flickr
Soldered on a rectangular piece of brass using silver solder.
WP_20190518_16_23_22_Pro by Andy, on Flickr
Milled channels in the square half of the bush to match the semi circular half.
WP_20190519_16_33_49_Pro (2) by Andy, on Flickr
Drilled and reamed the bushes to 9/32" diameter.
WP_20190519_17_16_04_Pro (2) by Andy, on Flickr
Parting off each bush
WP_20190519_17_23_48_Pro by Andy, on Flickr
WP_20190519_17_24_30_Pro by Andy, on Flickr
WP_20190519_17_37_40_Pro by Andy, on Flickr
Bushes separated into halves by carefully heating to break the silver solder joint.
WP_20190519_17_55_53_Pro by Andy, on Flickr
Fitted on the connecting rod fork, retained by the straps and temporary wedges.
WP_20190520_16_28_28_Pro by Andy, on Flickr
The bearings seem to be a good fit, there is no slack or binding. Jury rigged and it turns over smoothly.
WP_20190520_20_02_06_Pro (2) by Andy, on Flickr
There is a long way to go with this engine particularly trying to achieve the beautiful finishes I see on other Stuart Major seen in pictures and videos on the Internet
Andy
« Reply #107 on: May 27, 2019, 11:29:00 AM »
Nice job on the brasses Andy!
Offline Chipswitheverything
« Reply #108 on: May 27, 2019, 01:01:10 PM »
Hi Andy, a good result on the split brasses : there is a load of work in these innocent looking components, more than meets the eye once they are all finished, and lucky you, you have eight more pairs to do in the parallel motion links, and then the tiddly half shells for the oval ended radius rods....! But very satisfying to be able to put some assemblies together and see it moving sweetly.  Dave
Offline Chipmaster
« Reply #109 on: May 27, 2019, 02:27:21 PM »
Cheers George and Dave, you certainly have to be in it for the long term with this one. I have started work on a set of I F Allman castings which I’ll probably be able to complete sooner following Jason B’s excellent drawings.
Andy
« Reply #110 on: May 27, 2019, 04:18:34 PM »
Looks like you have got all the fun bits done now Andy, only the fiddly little bits left :LittleDevil:
Allman is making good progress, at this rate I'll need to complete a few more drawings.
Got this little one to run today but had to forego the flames :(
<a href="https://www.youtube.com/watch?v=kYWZrxXmRgg" target="_blank">http://www.youtube.com/watch?v=kYWZrxXmRgg</a>
Offline jeff l
« Reply #111 on: May 27, 2019, 04:21:43 PM »
if interested I made a form tool  for the parallel motion bearing spacers , it made the job of making these easy . You can borrow it if you wish just pay postage to and from .Or I can give you instructions on how to make one your choice .Jeff
Offline creepy
« Reply #112 on: June 09, 2019, 11:10:02 AM »
Hi Andy
I'm fairly new here, but I have been through all your build videos of the Major and all I can say is wow, what a fantastic build you are doing.
Your skill to build this very complex engine is outstanding, I don't know if a lot of people outside the forum could appreciate the amount of work that goes into a build like this.
I'm currently building it's little brother and that is very taxing, I don't have the equipment to build something this big, so I'll be watching you complete this monster.
What I love about Model Engineers is how different we approach a build, we all learn from each other.
All the best.
Gary
Offline Chipmaster
« Reply #113 on: June 10, 2019, 07:45:12 PM »
Well Gary I am overwhelmed by that. I have to say there are other MEM members who have built the Stuart Major before me who have provided plenty of practical advice via posts and personal messages. It could be a daunting project so I like to take breaks making other smaller models. Like you I don’t have all the appropriate equipment for many aspects of  the build but improvising and overcoming problems is a part of this hobby that gives great satisfaction.
Andy
« Last Edit: June 13, 2019, 09:29:58 PM by Chipmaster »
Offline Chipmaster
« Reply #114 on: June 13, 2019, 09:53:43 PM »
This afternoon I had a go at the piston, the kit included a piece of 55mm diameter cast iron bar sawn perfectly square and long enough for holding in the chuck. The kit also includes two cast iron piston rings
Copied from the plans:
Piston by Andy, on Flickr
Turned down to 1.75" and forming the piston ring grooves with a parting tool.
WP_20190613_17_08_33_Pro by Andy, on Flickr
Tapering the bore using a tiny boring tool and offsetting the topslide.
WP_20190613_17_37_46_Pro by Andy, on Flickr
WP_20190613_17_37_54_Pro by Andy, on Flickr
Forming the recess in the top of the piston some cuts with the lathe in reverse.
WP_20190613_20_28_20_Pro by Andy, on Flickr
and some cuts with the lathe running forwards,
WP_20190613_20_33_04_Pro by Andy, on Flickr
Recess done.
WP_20190613_20_33_13_Pro by Andy, on Flickr
Parting off the piston
WP_20190613_20_37_01_Pro by Andy, on Flickr
Almost there
WP_20190613_20_47_13_Pro by Andy, on Flickr
It's off,  phew  :DrinkPint:
WP_20190613_20_53_10_Pro by Andy, on Flickr
I'll do the recess on the other side tomorrow.
WP_20190613_20_56_29_Pro by Andy, on Flickr
Andy
« Last Edit: June 14, 2019, 04:20:06 PM by Chipmaster »
Offline gary.a.ayres
« Reply #115 on: June 13, 2019, 10:48:22 PM »
Phenomenal build...!
Offline creepy
« Reply #116 on: June 14, 2019, 10:53:58 AM »
Great work Andy.
I hate machining pistons
Gary
Offline Chipmaster
« Reply #117 on: June 14, 2019, 02:50:32 PM »
Finishing the piston.
Boring out the recess in the underside of the piston.
Finished
I made a dummy piston rod because I only had a short length of 1/4" diameter stainless steel. The steel bar was held in a multi-collet chuck and the taper formed by angling the topslide to six degrees. A 2BA thread was cut on the end of the rod.
Piston rod by Andy, on Flickr
Looks OK.
Hi Gary, I reckon I prefer machining pistons - no surprises because I can see what's happening unlike boring long cylinders with flexing boring bars, oh and I like working with cast iron apart from the mess.
Andy
« Reply #118 on: June 14, 2019, 03:42:32 PM »
Hello Andy,
Still following along and admiring all your work.
Offline Chipmaster
« Reply #119 on: June 14, 2019, 07:42:53 PM »
Hi Thomas, thank you for your interest and compliments. I have started work on the cylinder head this afternoon. Had to stop when I was called in for dinner this evening.
Andy
