Author Topic: Stuart Major Beam Engine  (Read 88947 times)
Offline Chipmaster
Re: Stuart Major Beam Engine
« Reply #270 on: July 06, 2020, 09:31:43 PM »
I have resumed work on my Stuart Major after a three month break partly due to working on an Alyn Foundry I. F. Allman engine. I'm working on the slide valve but there is a problem, the valve rod as drawn can't be fitted inside the valve / steam chest because it is too long. Fortunately some months ago Dave'Chipswitheverything' forewarned me and set out the solution he had used.
Extracts from the drawings,
[url=https://flic.kr/p/2jiJy9i]
[url=https://flic.kr/p/2jiJEys]
Slide valve casting
[url=https://flic.kr/p/2ji6ctJ]
Slide valve by Andy, on Flickr
The casting was large enough have a socket milled to accommodate the end of the valve rod and dispense with the 1/8" steel plate held on by 2BA screws shown in the drawings.
Milling the slide valve,
The valve rod, instead of 9/64" I used 4mm diameter stainless threaded 5BA on the outward end and a stainless steel lug silver soldered on to drive the slide valve.
Valve rod by Andy, on Flickr
Slide valve and valve rod by Andy, on Flickr
These two pictures demonstrate the problem,
Slide valve, valve rod and valve chest. by Andy, on Flickr
How is the builder supposed to fit the valve rod inside the steam chest?
The solution is to bore and thread a large say 7/16" hole in the bottom of the chest so that the valve rod can be passed through the hole which can be sealed with a threaded plug. That's what I'll do tomorrow.
Andy
« Last Edit: July 07, 2020, 10:34:53 AM by Chipmaster »
simplyloco
« Reply #271 on: July 06, 2020, 10:45:28 PM »
Thank you for that insight. A great help!
« Reply #272 on: July 07, 2020, 07:16:18 AM »
The other option would be to make the valve rod in two parts, drill and thread the plain shank to take a longer threaded section rather than have it all one length. Your rod looks to be longer than drawing, I make it that the unthreaded length is 1.657 which will fit into the 1.813 cavity.
That way you can fit the rod, push it up through the hole and screw in the threaded part, could even just do a plain hole and loctite the two together but you won't get it apart easily if needed.
If you do go for the plug option it would be worth making that to take a drain cock so you can get any condensate out of the valve chest if you are going to run on steam.
« Last Edit: July 07, 2020, 07:22:57 AM by Jasonb »
Offline Chipmaster
« Reply #273 on: July 07, 2020, 08:19:14 AM »
Yes Jason the threaded section of my rod is considerably longer than specified because it came in handy having been a test piece when I set up a small Coventry Diehead to cut 5BA threads for my Allman exhaust valve rod. I’ll trim it to the required length eventually.
As I intend to run the engine on steam it also occurred to me that a drain cock would be useful beneath the steam chest.
Andy
« Last Edit: July 07, 2020, 09:56:54 AM by Chipmaster »
Offline Alyn Foundry
« Reply #274 on: July 07, 2020, 11:24:33 AM »
A wee " T " nut ??  ;)
Offline Chipmaster
« Reply #275 on: July 07, 2020, 12:01:21 PM »
Yes Graham that was always a possibility too  :ThumbsUp:
Andy
Offline Chipmaster
« Reply #276 on: July 07, 2020, 08:05:18 PM »
To complete the valve chest I bored and threaded a 7/16" x 26 tpi hole in the bottom of the chest.  The lug on the end of the valve rod was ground down until it would pass through the 7/16 as the threaded end went through the gland at the top of the valve chest.
A brass bush 7/16" x 26 tpi was made with a 3/16" x40 tpi internal thread to fit a union cock for draining the valve chest.
The slide valve will require an hour or more lapping to produce an acceptable finish on the port face.
Andy
simplyloco
« Reply #277 on: July 07, 2020, 08:33:48 PM »
Excellent!
Offline Chipmaster
« Reply #278 on: July 07, 2020, 10:06:02 PM »
Hello John, pleased we have another ST Major builder, I must get a move on.
Andy
simplyloco
« Reply #279 on: July 08, 2020, 12:10:25 AM »
No Hurry!
Offline Johnmcc69
  • Erie Pa., USA
« Reply #280 on: July 08, 2020, 03:09:07 PM »
 :ThumbsUp:
 Nice solution!
Offline Chipswitheverything
« Reply #281 on: July 09, 2020, 04:10:17 PM »
Hi Andy, pleased to see nice progress on the beam engine again, and the drain cock in the plug on the s' chest is a nice refinement, which ( if I ever get back in my workshop, still curtailed in that after so long ), I can think of adding.   Dave
simplyloco
« Reply #283 on: July 10, 2020, 11:04:53 PM »
 Lovely job.
« Reply #284 on: July 11, 2020, 03:28:54 PM »
Hi Andy, that's coming on well.  Seem to remember putting the strap on the little GHT rotary table to do the outside profile, also running a bullnose slot drill along the sheave side of the boss to blend the two shapes together.
  Don't know if John, who is chewing over the prospective work on his Major, happens to have caught up with the forum write up that I did on my engine?, ( albeit still awaiting the finishing stages even now )  - my pics and write up are in my posts starting in March 2016.    Dave
