Author Topic: RUST  (Read 7393 times)
Offline Alan Haisley
Re: RUST
« Reply #15 on: February 27, 2014, 06:50:39 PM »
If possible, throw a plastic blanket over the machine and burn a 40W light bulb or similar source of small heat under the blanket. It should only take a small temperature differential to keep the moisture outside.  :old:
Online sco
Re: RUST
« Reply #16 on: February 27, 2014, 07:49:52 PM »
Isn't plastic the worst thing as it traps the moisture in so you get a green house effect?
Ars longa, vita brevis.
Re: RUST
« Reply #17 on: February 27, 2014, 09:27:38 PM »
Without the heat source it would be bad but so long as the temperature under the sheet is more than that outside the sheet it should work. A lot of the "green house effect" comes from plant respiration along with watering the plants.
Alan
