Author Topic: brushed DC motor as a generator  (Read 7373 times)
Offline airmodel
« on: February 14, 2014, 05:45:40 AM »
Hi everyone
After I visited the 2009 NAMES show I had a look at the Henry Ford museum. I liked the look of the old DC generators made by Edison at the museum, so four weeks later I made a working model.
 This is a very simple model as there are only two wires for the output and it does not matter which direction the generator spins. It was a 24 volt motor and to make it generate the amature is spun by a model motor.
The video shows what happens when only one magnet is used and it still generates DC.  http://youtu.be/yWF0mKSrsK4
Offline rockknocker
Re: brushed DC motor as a generator
« Reply #1 on: February 14, 2014, 08:33:40 PM »
That is very nice looking! Those old motors and generators have a lot more "character" than modern ones do, for sure.
Offline airmodel
« Reply #2 on: February 14, 2014, 10:44:19 PM »
 rockknocker  Welcome to the forum.
« Reply #3 on: February 15, 2014, 12:41:56 AM »
Airmodel being in the electrical field I can appreciate your project. That is a nice setup and a great looking generator. I like.......... :praise2:
« Reply #4 on: February 15, 2014, 01:19:07 AM »
Airmodel, as I have said before, I don't so the sparky parts but love the castings and the finished result. Sure looks like it is working well to my untrained eye.
Rockknocker, if you will, please post and bit about yourself in the intro section so we can get to know you and your interests.
Offline Ian S C
« Reply #5 on: February 16, 2014, 12:07:25 PM »
Airmodel,  looks a good one, I too convert old electric motors into alternators, and generators, I use them as a load for my hot air/Stirling engines.     Ian S C
« Reply #6 on: February 16, 2014, 12:14:28 PM »
Hey Airmodel,
I like that a lot.   It's nice to put the engines we make on a load and make them do something.    this is a perfect way to do it!
Nicely made ! :ThumbsUp:
« Reply #7 on: February 16, 2014, 12:59:50 PM »
That looks great. It would look swell too in a diorama of some sort.
Offline airmodel
« Reply #8 on: February 16, 2014, 11:45:40 PM »
Don  I have no formal training in electricity. All I know is self taught. It is good to see that others are interested in the same thing.
 Bill  I was hoping that you would see this post. DC generators are very simple to understand. The only thing you have to watch is keep the brush alignment the same as it was in the motor.
Offline PStechPaul
  • Cockeysville, MD 21030
« Reply #9 on: February 22, 2014, 08:59:49 AM »
Nice looking little motor/generator. The casting process is impressive! Did you also make or modify the armature? And where did you get the curved magnets for the field?
My interests at the moment are three phase AC induction motors (3 cheers for Tesla!), and switched reluctance motors which use only electromagnets and iron.
I recently saw the movie "Edison the Man" where he had built two huge dynamos to power the lights on a street to demonstrate their superiority to gas, and he had a problem with synchronizing them and they burned up. But then he had the idea of connecting the governors together and it worked. But I don't know why he had to connect two in parallel. He could have used two separate circuits. And I suppose they didn't have fuses and circuit breakers in those days either? Probably they did, but then they would not have been able to shoot such a dramatic scene with big sparks and noise and smoke! Even in more modern and futuristic movies and shows like "Star Trek", they always have exploding control panels, while that would almost never happen in a well protected and properly engineered system.
Offline Ian S C
« Reply #10 on: February 22, 2014, 11:02:10 AM »
On one generator, and one motor that I have built from scratch, I mounted the brushes so that they can be rotated about 90* either side of there normal position, I like fiddling around with things, that way with the motor there is some speed control, as the load goes on, it can be adjusted for the least sparks at the comutator, It's an open frame motor, and it will run my "Super Adept" lathe with ease, and has more than enough power to run my power hacksaw(Junior blades).    Ian S C
« Reply #11 on: February 22, 2014, 11:04:06 AM »
As I understand it....and I might not....it was a phasing issue ....regarding Edison and his generators.
Coupling the two governors together would result in one driving the other....which is fine I suppose.   It just means 1 of the inputs of the dynamic system was removed...and there must have been a fixed gain added to the other engine throttle...
« Reply #12 on: February 23, 2014, 03:24:34 PM »
In order to parallel the Dynamo's, a means to control the voltage had to be installed or one generator would feed into the other. Just like connecting two batteries together with different voltages. The high voltage battery will charge the lower voltage battery and it would probably blow up. Then in order to have both pulling the same load the governor had to be adjusted the same or one would put out more power then the other. In other words load one engine more then the other.
« Reply #13 on: February 23, 2014, 04:32:12 PM »
This is all reminding me, when in the good old days on the 707, we had to parallel four AC generators by adjusting the phase of each generator.
« Reply #14 on: February 23, 2014, 04:48:16 PM »
Hi Vince, the setup we had when I was in school we had to adjust the phases in order to parallel, because the generators were on the same shaft and the winding were not set in the same identical position to each one. There was a crank to rotate them.
When you have different prime movers you don't have to shift the phasing other then to match phase rotation. But provision are made to be able to parallel them at the proper moment or in sync as it's called.
