Author Topic: Demon V8 updates, getting them?  (Read 3036 times)
Online stevehuckss396
  • Sterling Heights, MI USA
« on: February 08, 2014, 05:23:18 PM »
I just sent out an update and had about 10 "undeliverable" due to email addresses not existing anymore and other things. If you have purchased the plans and have not received an update, PM me your name and email address you used when you bought the plans. If I find you on the list I will update your information and get you the latest set.
I found out a few weeks ago that the distributor gear set I used was supplied by Berg who now has a $200 minimum order on online orders. I found new sources for the gears and seals. The drawings were updated to work with the new gears and over all should save you about $90 in material costs.
Offline Mike OConnor
  • Tallahassee, Florida USA
Re: Demon V8 updates, getting them?
« Reply #1 on: February 08, 2014, 05:40:13 PM »
Hi Steve,
I have been getting your updates. Thanks for keeping us current. I really appreciate your efforts.
Thank you!
Offline Doc
  • USA ND
« Reply #2 on: February 08, 2014, 05:41:27 PM »
Hi Steve,
Thank you!
I second that!!
Thanks Steve!
« Reply #3 on: June 04, 2020, 02:52:52 PM »
For anybody building the little demon, the correct part number for the gear stock for the water pump is
A 1B 9-Y321009
And it is now called pinion wire.
Go figure.
