Author Topic: Chuck Fellows Carburetor, V4.0  (Read 6610 times)
Offline cfellows
« on: February 05, 2014, 12:09:31 AM »
While I really liked the design of my previous carburetor, it has a few things I think can be improved upon.
First, while the screw-in throttle was simple and elegant, it just doesn't fit well enough to consistently control the air and fuel.  I soon discovered that even with the throttle screwed all the way in, the engine tended to keep running which means some air (and fuel) was getting by.
Second, the separate needle valve assembly was more complex than it needs to be.  And, the sewing needle used for the mixer doesn't have the ideal shape... it should be conical, not elliptical.
Third, most model airplane carburetors I've seen have the needle valve coming in from the bottom of the carb, not the top.  Maybe their design is just simpler or cheaper, or maybe they know something I don't.
So, here we go with a new design that more closely approximates those of commercially available RC carburetors.  I started with a piece of 3/8" square brass bar chucked in the lathe and cut a round boss on the end.
Next, I drilled a 1/16" hole about 1/2" deep through the center.
Then I tapered all 4 sides of what is to become the bottom of the carburetor.  This is done partially for appearances and partially to make it easier to affix the fuel supply nipple.
Next I drilled and tapped a 6-32 hole in one side.  The fuel supply nipple will screw into this hole, which connects with the center hole drilled earlier.
Then I cross drilled a 1/4" hole which will receive the venturi tube...
Here is the venturi tube.  I started with 1/4" brass rod, drilled a 1/8" hole through the center, threaded one end with 1/4" model pipe taper threads, and used a countersink drill to open a taper for the air intake on the other end.
Then I soft soldered the venturi tube into the body.  I cleaned both parts with denatured alcohol, slathered on some plumber's flux, fixed it in the vise, placed a ring of solder around the joint, then heated it from below with my Mapp Gas torch until the solder melted and flowed into the joint.
And, here is the built up carburetor body so far...
Chuck
Re: Chuck Fellows Carburetor, V4.0
« Reply #1 on: February 05, 2014, 01:07:52 AM »
Nifty.
How did you do the tapers?
Offline rebush
« Reply #2 on: February 05, 2014, 01:31:37 AM »
Chuck: Looking good. Will be following along. Thanks for taking the time to post your progress. Roger
Hopelessly lost but making darn good time.
Offline cfellows
« Reply #3 on: February 05, 2014, 04:02:36 PM »
Nifty.
Thanks, Carl.  I clamped the work piece in a cross slide mounted vice, set at an angle, and faced off the angle with an end mill chucked in the lathe spindle.
Chuck
Offline cfellows
« Reply #4 on: February 05, 2014, 11:30:09 PM »
Got the needle valve finished today.  I started with a 2-56 socket head cap screw.  I needed a way to chuck it in the lathe so I could turn the taper on the end.  So, I made a threaded sleeve from a small piece of brass rod.
Then I chucked the brass sleeve in the 3 jaw chuck, set the compound to 4 degrees off the screw axis and turned the taper.  The tip is about .025" in diameter.  I finished the taper surface with 1200 grit wet or dry sandpaper.
And here's what it looks like on the engine...
I used the following procedure to make the needle valve seat.
- When I originally made the body, but before I soldered in the venturi tube, I drilled a 1/16" hole from bottom thru into the opening that later received the venturi tube.
- After I soldered the venturi tube in place.  I used a .040" drill to go in through the 1/16" hole and drill through the wall of venturi tube.  I first used a 1/16" bit to dimple the side of the venturi tube to help center the .040" bit.
- Then I pressed a 1/8" length of 1/16" brass tubing into the 1/16" hole, seating it against the outside edge of the venturi tube.  The ID of the 1/16" tubing is about .032" and will serve as the seat for the needle valve.  If the seat ever gets worn, I can just drill out the old length of tube and insert another one.
Chuck
Offline cfellows
« Reply #5 on: February 06, 2014, 02:42:15 AM »
One more set of pictures for the day.  Here you can see the 3/16" cross hole drilled that will hold the throttle barrel.
In this closeup, you can see the fuel inlet from the needle valve.
Next I'll make the throttle assembly.  Here is a drawing of what it will look like...
Chuck
Offline cfellows
« Reply #6 on: February 06, 2014, 09:57:47 PM »
The carburetor is finished.  Here are a series of pictures.
I used a rubber o-ring and e-clip to hold the throttle in place and provide some stiffness so the throttle setting will stay put.
Tomorrow I hope to hook up the fuel line and try it out.
Chuck
« Last Edit: February 06, 2014, 10:01:41 PM by cfellows »
« Reply #7 on: February 07, 2014, 01:44:26 AM »
Hi Chuck,
Your carb will work but you'll run into a problem metering the fuel from idle to whatever rpm you want the engine to rev to. Let's say the throttle is wide open. With the needle valve adjusted to provide the correct air/fuel mixture the engine will run at an rpm controlled by the size of the venturi. Large venturi, more fuel, more rpm. (to a point)
Now when you shut the throttle down to the idle position the narrow venturi area will create a much stronger vacuum signal and therefore more fuel will be pulled through the needle valve. To compensate for this increase in fuel you can readjust the needle at which point when you try to throttle the engine it will either backfire or stall because of the lean condition.
That's why they make the air bleed port. If you find that you have this problem you can simply drill a hole from the top or bottom into the venturi of the carburetor (depends on the rotation). I would start off small and work up in diameter until you get a good mixture at idle and high speed.
Now I'm not saying yours won't work because I have heard of fellow using this type of carb without an air bleed and they work fine, well let's say satisfactorily.
I'm following along to see how you make out because there's always something to learn.
______________
« Last Edit: February 07, 2014, 01:47:53 AM by gbritnell »
Offline cfellows
« Reply #8 on: February 07, 2014, 05:49:45 AM »
Thanks for the comments, George.  I know that building a simple carburetor that works well across all speed ranges can be a daunting task.  My goal is to come up with a design that will let me achieve a slow steady idle that rarely misfires.  I would like a little bit of throttle but am not interested in running the engine over 1000 - 1500 RPM, and would mostly like to keep it at 500 - 600 RPM or less.
Chuck
Offline cfellows
Re: Chuck Fellows Carburetor, V4.0, Now Back to V3.0!
« Reply #9 on: February 10, 2014, 12:41:09 AM »
OK, I'm abandoning V4.0.  The throttle is too sensitive and there is no easy way to compensate for too rich a mixture at idle.
So, I'm back to version 3.0 with the simple threaded screw throttle.  However, I've made a couple of changes.
I've turned a smooth end that fits closely into the bore of the venturi.  The threaded portion ends short of the venturi opening.  I've also included a small nipple on the end of the throttle screw which will enter and close off the fuel aperture as the throttle reaches the idle point.
Here you can see the nipple through the venturi opening, although it's not in focus and kind of blurry.
I may have to fine tune this part, so the nipple is actually a 2-56 allen screw which is threaded into the end of the throttle screw.  I can remove and replace or resize the nipple as required.
I'm also going to make a new needle valve for it, one that has a straight, conical point instead of the elliptical shaped needle.
Chuck
Offline AussieJimG
  • Bywong, NSW, Australia
« Reply #10 on: February 10, 2014, 12:57:45 AM »
This is a fascinating project and I am enjoying every bit of it. Thanks Chuck (and the rest of you)
Offline cfellows
« Reply #11 on: February 12, 2014, 03:06:24 AM »
I got the engine running with this latest carb version, but I'm still not happy with it.  I've decided I need to go back and work on the valve timing on the engine before I do any further carb experimenting.  I won't be posting to this thread anymore, I'll just pick it up o my vertical single engine thread.
Chuck
