Author Topic: indexing  (Read 1836 times)
Offline krv3000
indexing
« on: February 03, 2014, 08:40:42 PM »
hi as i did not wont to jump on a nuther mans topic this is haw i made a indexing divice for my compact 8 lathe witch can be adapted to fit on simaler type of lathe on the drive belt side of the lathe ther is a bracet that you put the change wheels on to for scruw cuting and pawer feed behind the mane pully ther is a gear witch by chance i had a whurm wheel that fited made a bracet to fit on to the gear wheel bracet with a basick indexing plate with a detent its still work in progress as i need to refine and mack up more deviding plates right pics
