Author Topic: Shaft seals, need source  (Read 2072 times)
Offline stevehuckss396
  • Sterling Heights, MI
« on: February 02, 2014, 12:44:49 AM »
Hello!
I am looking for a source for shaft seals in 1/4 and 3/8 inch. I used to get them from WM Berg but they have implemented a $200 minimum order on there online orders and I dont want 50 of them. I use them as crankshaft seals. Anybody know of a source that will allow just a pair to be ordered?
Thanks
Offline Doc
  • USA ND
Re: Shaft seals, need source
« Reply #1 on: February 02, 2014, 01:50:03 AM »
I buy most of my seals and hardware at Mcmaster they do have  some 1/4 shaft seal with 3/8 od here. SEALS
Or won't these work for what you need?
« Reply #2 on: February 02, 2014, 02:03:02 AM »
Doc beat me to it Steve, but IIRC McMaster is where I got the ones for the Briggs engine. You might also check the Timken website. I may have gotten them there instead since I know they were Timken seals. Somewhere I still have the original paperwork and if I can finf it I will update this post. I am not sure what if any minimum Timken has though but if I did get them there, it wasn't an issue at the time.
« Reply #3 on: February 02, 2014, 02:33:21 AM »
Says "not for use with oil" so I kept looking. The 3/8 will work anyway.
« Reply #4 on: February 02, 2014, 02:48:21 AM »
I stumbled upon that site but found it impossible to find out what they have available.
Offline Doc
  • USA ND
« Reply #5 on: February 02, 2014, 02:59:55 AM »
Steve these are rated for oil and water.
From McMaster
Spring-Loaded PTFE Shaft Seals
Graphite-Reinforced PTFE—Excellent wear and extrusion resistance in liquids, steam, and other severe conditions. PV limit (pressure × velocity) is 15,000 psi-fpm for air; 300,000 psi-fpm for water; and 520,000 psi-fpm for oil. Color is black.
