Would a nylon washer be acceptable between HS and PCB? I don't have any mica.Funny you should mention contact with the system, as I ponder the practicality of the exposed ignition. Is it a problem to leave it hanging out in the open, exposed to fingers or bumping into? Consider housing the ignition PCB in a plastic shield? Cooling?Or is this overthink?You know I hate those ignitions buried in a wooden coffin underneath the engines.Mosey
