Author Topic: Victoria's Steam Plant Finished  (Read 7035 times)
Offline Robert Hornby
  • Terrigal NSW Australia
Re: Victoria's Steam Plant Finished
« Reply #15 on: January 16, 2014, 09:48:02 PM »
Thanks Frazier, How did you fix the prop to the shaft? I have been thinking about this as I know the full sized boats usually have a tapered shaft with keyway and end nut but that would be difficult on our size shafts I am thinking. I too am making the prop to the direction of the best rotation of the engine. It runs on no load at 5 psi clockwise and 7 psi anticlockwise. I am assuming this is to do with the timing and valve openings, but I am happy enough with it as it will not be going too far astern.
Robert
fcheslop
« Reply #16 on: January 16, 2014, 11:14:39 PM »
Hi Robert, The prop is tapped 5BA and will simply be screwed on with a lock nut so it doesn't  vanish into the lake. This boat maybe a lot smaller than youre build she is only 31inches from bow to stern and about a 7inch beam and to be honest has been a very difficult build and will admit Iv often thought about simply giving up on her.The engine is 5/16bore and 1/2 inch stroke double acting.I had started building her as a simple fill in build  :facepalm: . I prefer to do  true scale builds and think this one has taken far to much effort for what she is a semi scale model. At least when I do my own drawings I can only curse myself.
best wishes
frazer
fcheslop
« Reply #17 on: January 16, 2014, 11:26:29 PM »
Hi David, thanks marra/duck
cheers Nick dont know about heirloom Bat went to replace the ML7 :facepalm: but it was only collecting dust :Lol:
cheers
Offline ths
« Reply #18 on: January 17, 2014, 04:47:39 AM »
That's just beautiful Frazer.
All the best, Hugh.
Offline NickG
« Reply #19 on: January 17, 2014, 05:59:07 PM »
Ah well needs must but if I'd made it it definitely would be!
Offline arnoldb
  • Windhoek, Namibia
« Reply #20 on: January 19, 2014, 05:18:38 PM »
She's a beaut Frazer!  :NotWorthy:
Kind regards, Arnold
fcheslop
« Reply #21 on: January 19, 2014, 06:58:03 PM »
Thanks Arnold.Cheers Hugh
Hi Nick once they :Lol: are built the fun is over. I have a few nice ones locked away.It may be time they were brought out to play :lolb:
Cheers and thanks for the interest.
