Author Topic: 1/3rd scale V10  (Read 219417 times)
Offline keith5700
Re: 1/3rd scale V10
« Reply #90 on: December 09, 2014, 12:55:05 PM »
Yes it is time for an update.
I finished off the 2nd set of headers......
then i wanted to make some pretty things as I was starting to get bored, so I decided to finalise all the belt runs.
The supercharger will be driven from a shaft going along the side of the block, so I made the pulleys and clamps etc. for this..
This is just the belt tension pulley arm.
this is how it comes off the miller...
and this is after 2 hours of filing and polishing, and then a quick anodise..
Offline keith5700
Re: 1/3rd scale V10
« Reply #91 on: December 09, 2014, 01:02:17 PM »
So this is where I'm up to as of last night.
The mechanism for the variable valve timing isn't going too well.
I want the 2 idler pulleys on each belt to keep the tension the same, as the idler is pushed into the belt, but although the CAD says it should work, it doesn't in practice, so I'm doing a bit of trial and error with different pulley centres and pulley diameters.
Offline strictlybusiness1
  • ME., Tool Maker
Re: 1/3rd scale V10
« Reply #92 on: December 09, 2014, 02:35:32 PM »
Keith,
Your apparent dedication to perfection in producing each piece, while working with manual machines, should not be ignored or minimized! This is a dying art form! I take my hat off to you for your efforts! :praise2: :praise2:
Jim Allen, ME., Tool Maker
Offline metalmad
Re: 1/3rd scale V10
« Reply #93 on: December 14, 2014, 02:09:56 PM »
Simply Awesome Keith :ThumbsUp: :praise2:
Offline Nicolas
  • Hawkes Bay, New Zealand
Re: 1/3rd scale V10
« Reply #94 on: December 14, 2014, 02:23:49 PM »
Just caught up with this thread, I'm amazed :o
Incredible work, I'm already looking forward to the next update :)
Offline Coopertje
Re: 1/3rd scale V10
« Reply #95 on: December 14, 2014, 02:54:50 PM »
Very nice work Keith, your finishing and detail are almost unreal  :NotWorthy:
Looking forward to the next update.
Regards Jeroen
Offline keith5700
Re: 1/3rd scale V10
« Reply #96 on: January 14, 2015, 09:27:19 PM »
Thanks chaps.
Managed some work over Xmas.
I mainly wanted to make the inserts for the cam covers as these were going to be slightly tricky.
It took 4 full days to make them, then I realised on one side I'd put the plug holes in 1mm out, so this took another day to sort out.
I managed to offset the o ring holes 0.5mm on the cover, and offset turn the spark plug tubes by 0.5mm.
This should make sense from the pics.
Offline KB
Re: 1/3rd scale V10
« Reply #97 on: January 14, 2015, 09:32:04 PM »
Amazing craftsmanship Keith.
I look forward to each update. Thanks.
Offline keith5700
Re: 1/3rd scale V10
« Reply #98 on: January 14, 2015, 09:36:50 PM »
I also sorted out the cam belt tensioners.
I wanted a nice smooth spring system as there will be a lot of slack to take up when the variable timing pulleys operate.
I went for lever arms with a spring loaded piston in the front of the head. The levers pick up the piston through a slot in the head. I'll get some close ups later, I forgot when I assembled it.
Offline Greg Haisley
Re: 1/3rd scale V10
« Reply #99 on: January 14, 2015, 10:04:14 PM »
Awesome craftsmanship !!! Keith I wish you lived in the states, I'd hire you in a New York second.
Cheers,
Greg Haisley
Re: 1/3rd scale V10
« Reply #100 on: January 15, 2015, 12:23:35 AM »
Was cruising through and got stopped here. Wow!!! I mean wow!!!
Read the entire thread...I see I popped in last March...so it was great to catch up.
It's obvious you're not in the states...but I haven't figured out where you are.
Offline 90LX_Notch
    • YouTube Channel
Re: 1/3rd scale V10
« Reply #101 on: January 15, 2015, 03:14:58 AM »
Keith-
Your attention to detail and your finishing techniques really set your engines apart. They are true works of art.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline keith5700
Re: 1/3rd scale V10
« Reply #102 on: February 09, 2015, 12:59:26 PM »
Not much to report on the V10 front.
I've had the V8 on youtube for over a year now, but there has been a growing group of commentors who don't believe it is a running engine.
I've been accused of all sorts of things, liar, cheat, fraud etc.
So I finally got round to doing another video which should put it all to rest.
There's some funny exhaust smoking going on, ie. only smoking on one side, so that needs a look at.
We did some V10 stuff at the same time so it may be of interest to someone.
Cheers.
Offline ///
  • Perf, Straya
Re: 1/3rd scale V10
« Reply #103 on: February 09, 2015, 01:49:03 PM »
Keith, are these comments at youtube?
Ignore them, there's no shortage of idiots with only half a braincell on there :(
It wouldn't surprise me if some of the comments are from people that are fully aware it's real, but they just get their kicks out of creating a stir... youtube seems to be the biggest troll magnet.
I'm seeing more and more video's there where commenting has been disabled, smart move I reckon.
Anyway, on a lighter note, I've really been looking forward to a new installment(longtime lurker)
I love your work and I'm learning a hell of a lot from your posts.
Cheers!
« Last Edit: February 09, 2015, 01:57:51 PM by /// »
Simon
"The reality is that without cheap imported machines, I would be spending my time doing something less creative and less enjoyable" - Captain Jerry
Re: 1/3rd scale V10
« Reply #104 on: February 09, 2015, 02:29:04 PM »
Amazing video Keith.  I would not worry too much on what is said on utube.
