Author Topic: 1/3rd scale V10  (Read 295645 times)
Re: 1/3rd scale V10
« Reply #285 on: December 23, 2016, 03:17:31 AM »
That is one beautiful engine! Can't wait to see it running. Especially from the front ......looking at the belts!
Offline michelko
Re: 1/3rd scale V10
« Reply #286 on: February 03, 2017, 06:02:01 PM »
Hi keith i am working on a similar setup for spark and fuel for my bugatti engine.
Having big trobble with noise in the rpm signal. Could you please explain your system and the setup of sparkwires coils etc.?
Regards michael
Offline keith5700
Re: 1/3rd scale V10
« Reply #287 on: February 03, 2017, 09:15:11 PM »
Answered on your thread, to keep your project all in one place.
Offline michelko
Re: 1/3rd scale V10
« Reply #288 on: February 06, 2017, 08:52:13 PM »
Keith,
Could you explain how you did the triggering for ignition/injection?
Thanks.
Offline keith5700
Re: 1/3rd scale V10
« Reply #289 on: February 09, 2017, 10:39:02 PM »
Michael, sorry I missed this.
The main trigger is off the crank. The wheel is 30-1 tooth. The sensor is simple 2 wire vr type.
As I'm using full sequential ignition rather than wasted spark I then had to put a sensor on a camshaft. This is a hall sensor with a single magnet.
Re: 1/3rd scale V10
« Reply #290 on: February 09, 2017, 11:20:38 PM »
 :o :o :o :o :o
Just came across this for the first time.
Wow. That is some real craftmanship.  :ThumbsUp:
Offline ThomasM
    • My modelengines
Re: 1/3rd scale V10
« Reply #291 on: June 18, 2017, 07:56:01 PM »
Hello Keith,
Unbelievable. Someone who is not related to model engineering or metal manufacturing probably could not be able to understand how much engineering and manufacturing skills are needed for such a project. This is way of my actual skills and manufacturing abilities and it is - again - unbelievable.
Best regards,
Offline Nick_G
Re: 1/3rd scale V10
« Reply #292 on: June 18, 2017, 08:08:30 PM »
Sublime.
I don't have a good enough command of English to express how fantastic I think the whole project is from design to construction.  :ThumbsUp:
Nick
Offline scc
  • Lancashire, UK
Re: 1/3rd scale V10
« Reply #293 on: June 18, 2017, 09:39:37 PM »
WOW!!   I can only echo Nick's last comment :praise2: :praise2: :praise2:
Best Wishes      Terry
Offline ClaytonFirth
  • Brisbane, Australia
Re: 1/3rd scale V10
« Reply #294 on: July 11, 2017, 02:30:33 AM »
Absolutely amazing work Keith. Are you still working on this project? It would be brilliant to see this working with the supercharger!.
Clayton
Offline keith5700
Re: 1/3rd scale V10
« Reply #295 on: July 13, 2017, 12:50:04 PM »
hello, engine is pretty much the same still, but I have made a crude dyno, so just need some time to set it all up again and try and get some power figures.
I don't think the supercharger will ever get fitted. I'm thinking about whether to do one more engine at the moment. If I decide to do it then that will take up the next 2-3 years.
Re: 1/3rd scale V10
« Reply #296 on: July 13, 2017, 02:27:13 PM »
Hi Keith, sure hope you keep us up to date on whatever project you decide to do.
Offline keith5700
Re: 1/3rd scale V10
« Reply #297 on: September 22, 2017, 12:58:09 PM »
ok, update time. I've decided I'm going to make a 1/3 scale car/buggy/offroader to put the engine in. There's been too many people over the past few years asking why no-one ever puts one of these model engines in a car and get them to do some work. So we'll see why. It may be a complete disaster, especially with the V10, as there's so much stuff which has to go in with it to run.
Not sure where 10 x couilpacks are going to fit for a start!
Anyway, thats the plan at the moment.
I'm just collecting bits at the moment, and drawing up some preliminary designs.
The engine is still smoking badly so I decided to do something about it.
Removing the heads showed some cylinders far worse than others.
first trial was to put seals on the valve stems. the only way I could think was to O ring the stems. I had to make a new set of valves, but they are all in now, and engine is running.
Result is....no difference. Engine still smokes. At least I know now that it's the rings, or, lack of proper oil control ring.
So that's next on the list.
I tried to run it on the 'dyno' (friction disc and kitchen scales) but above 3000rpm it won't go into full load. I've had the fuel and ignition maps all over the range but it doesn't want to know.
I think now that it is being starved of air. the inlet system is fine for free revving, but to produce any power it needs opening up. Lots.
I need to cure the oil problem so I can get a wideband O2 sensor in the exhaust. trying to map the fuel by ear is a complete waste of time with this. Plus you can't hold a specific rpm/load position long enough to change things on the fly.
On my full sized engines I used the datalogging facility to great effect. Go for a run, look at the datalogs, and adjust fuel map in the house, whilst having tea!
So, oil problem needs solving first. If I can't do that then there's no point carrying on.
All the black oil on the bench came out of a manifold joint after about 15mins running.
Online Roger B
Re: 1/3rd scale V10
« Reply #298 on: September 22, 2017, 06:11:37 PM »
It looks magnificent as ever  :praise2:  :praise2:
Is there a pattern to the oil burning cylinders? Are they the same on both banks? If so there could be excessive oil flow from the adjacent mains/big ends.
What is the cam timing? Is this restricting power over 3000rpm?
Offline Mayhugh1
Re: 1/3rd scale V10
« Reply #299 on: September 23, 2017, 12:00:26 AM »
Keith,
I'm wondering what weight engine oil you're using and what oil pressure you're running? Immaculate work, by the way. - Terry
