Author Topic: 1/3rd scale V10  (Read 293302 times)
Re: 1/3rd scale V10
« Reply #210 on: February 23, 2016, 02:19:12 AM »
That is really impressive, i'm sure i could not make that at all      brilliant.....something to aspire to.......humbling........
Offline keith5700
Re: 1/3rd scale V10
« Reply #211 on: February 23, 2016, 07:58:46 AM »
Keith
great work
why is there pictures with no holes in between ports and in between ports on others????
I was also trying to figure out valve configuration " intake ,spark plug and heather "they match
for number one and then  1/4 of the manifold is missing ???
is it camera angle ???
Lots of question marks there. I thought 2 centre holes would look ok, but they didn't, so I banged 2 more in, between pics.
Not sure what spark plug and heather means?
The intake pipes were just plonked on the top to see what the colour looked like, ie. could I leave them as polished. I decided not, so they will get shot peened shortly.
I couldn't get them any more rearwards because of the big boss on the end.
The pipes are seperated as much as I dare. The inlet manifold will then distribute further out to the valves.
My inlet pipes would have looked ridiculous if they'd stretched out to line up with all 5 intakes.
Thanks everyone for comments. Cheers.
Offline gadabout
Re: 1/3rd scale V10
« Reply #212 on: February 23, 2016, 08:33:02 AM »
Keith, how do you machine the bores of the manifold tubes ?
thanks
Mark
Re: 1/3rd scale V10
« Reply #213 on: February 23, 2016, 07:44:17 PM »
thanks
Mark
Hi Keith, a fantanstic work and very well done repair.
Same question as from Mark is in my head.
Two straight bores from each side ?
Offline keith5700
Re: 1/3rd scale V10
« Reply #214 on: February 23, 2016, 09:58:04 PM »
The holes in at the moment are 8mm diameter and go in about 15mm. The through holes will be 5mm diameter, but they're not in yet. I need to make another jig first so I'm waiting till I get the other side done first.
I'll try and get a drawing up tomorrow to show the holes. The first thing I drew was the through holes, and then the rest was based around these.
Cheers.
Offline keith5700
Re: 1/3rd scale V10
« Reply #215 on: February 24, 2016, 12:49:19 PM »
This is how I'll get through. I'll need to open them up a bit with a small ball ended burr. Not sure how much air this engine will actually need.
Offline keith5700
Re: 1/3rd scale V10
« Reply #216 on: May 03, 2016, 01:23:05 PM »
Still plodding along.I've been cutting corners a bit lately as I want to get the thing running.
So stuff like variable cam timing and superchargers will have to be added later, as will odd looking
bolts and other bits and bobs.
For now I just want to see it running on a single injector, which is inside the top plenum chamber.
I'll post a pic of this later, I don't seem to have one of the plenum internals at the moment.
I've got the throttle position sensor working, and the injector wired up.
The Megasquirt has been programmed to fire the injector, so I just need to plumb the fuel in and it should fire up.
Re: 1/3rd scale V10
« Reply #217 on: May 03, 2016, 02:28:04 PM »
Good luck for the first start  :ThumbsUp:  :ThumbsUp:  :wine1:
Re: 1/3rd scale V10
« Reply #218 on: May 03, 2016, 03:11:55 PM »
Steamer want big Vrooooom!!!!    8-)
Sorry Steve....... 8)
Re: 1/3rd scale V10
« Reply #219 on: May 03, 2016, 07:09:21 PM »
Keith, I would like to wish you good luck for the first start of your engine.
Offline NickG
Re: 1/3rd scale V10
« Reply #220 on: May 03, 2016, 08:23:37 PM »
This is insane, never seen / known anything like it. Congratulations, can't wait to hear it!
Sent from my LG-H340n using Tapatalk
Re: 1/3rd scale V10
« Reply #221 on: May 03, 2016, 08:37:41 PM »
Keith - I'm sure that we are many here who are looking forward to see a video of it running - so good luck or should I say ; break a leg ?
Beautiful as usual from you.
Offline MrDude_1
  • Jr. member
Re: 1/3rd scale V10
« Reply #222 on: May 03, 2016, 09:15:17 PM »
What sensor did you use for your TPS?
I could really use one that small for another unrelated project.
Re: 1/3rd scale V10
« Reply #223 on: May 03, 2016, 09:51:43 PM »
Wow! What others have said...stunning, insane, vrooom.
Re: 1/3rd scale V10
« Reply #224 on: May 04, 2016, 05:59:23 AM »
Just have to get my "Me too!" in here.  Just incredible.
Can't wait to see it go!
